587,405 active members*
2,925 visitors online*
    Mar 2016
    Angry Laser cutting 3/8 steel
    Hey. I have a Trumpf TruLaser 3040 and TruFlow 5000 laser. Everytime I cut 3/8 steel it never cuts good, if at all. Always have problems with the parts sticking into the sheets. I'm using the correct tech table and everything but something is clearly wrong. The previous employee before me knew lots about it and seemed to cut good for him. But he didn't share any of that knowledge to me. I've fiddle around tweaking the settings to what the Trumpf data collection manual says but even with the settings they give me the parts still stick into the sheet. It's so bad most of the time I can't even hammer the parts out. Every other thickness of steel cuts perfect without any issues. I've tried using a different nozzle size and nothing seems to be working. It almost seems like when it's cutting it's getting too hot. I've noticed when it's cutting there is a small bit of smoke coming out from where it had cut. I've lowered the power and changed speeds and you name it I've done it. If anyone has any ideas for me, tips or something please let me know. I'm tired of this frustration.
    Thanks!!
    Jul 2014
    115
    Re: Laser cutting 3/8 steel
    Have you already experimented with pierce settings, leadin and leadout cuts , overlap adjustments ..... ?
    Best regards,
    Walter
  1. [Need help] Diy laser cutting stainless steel
    By ahdvip1 in forum Laser Hardware
    Last Post: 03-22-2014, 05:53 PM
  2. Stainless Steel Cutting Laser
    By SDSUSA in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-16-2013, 02:34 AM
  3. LIMAC fiber laser cutting machine for stainless steel cutting video
    By limacchina in forum Fiber Laser Cutting Topics
    Last Post: 05-05-2013, 05:24 PM
  4. CNC Steel Laser Cutting
    By M250cnc in forum Employment Opportunity
    Last Post: 04-16-2009, 12:32 PM
