587,535 active members*
2,538 visitors online*
IndustryArena Forum > CAM Software > Mastercam > pocket first or contour?
    Nov 2007
    my part looks kinda like a shallow tray with a small projection sticking out
    3 questions;
    a) Should i run surface rough pocket and then surface rough contour or the other way?
    b) When i run rough restmill,it eats into the walls of the tray though i asked it to finish the leftovers of the previous op.
    c) The depth of the projection doesn't seem to be enough.can i measure the graphic from verify.
    i am using mcam9
    Attached Files Attached Files
    Apr 2003
    3578
    Well here is a starter I did the first side look at my ops that are in the tool group cadcam.Sorry did not do the other side as I am tired as it has been along day. Hope this gives you a good start.
    Cadcam
    Cadcam
    Nov 2007
    thanks a lot!
    this really helps
  1. DesignCad 3DMax and Contour Cam
    By BCwanderer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-06-2007, 02:16 PM
  2. Contour probe digitizing
    By Sanghera in forum Digitizing and Laser Digitizing
    Last Post: 02-04-2007, 04:24 PM
  3. Workholding for contour of parts
    By Pharkas in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-08-2006, 04:03 PM
  4. Bad Contour Error while Pocketing
    By sundara in forum BobCad-Cam
    Last Post: 05-29-2005, 12:10 PM
  5. contour profile
    By stevieboy in forum Mastercam
    Last Post: 10-15-2003, 07:40 PM
