Originally Posted by
Potatohead908
Oh and I don't have flood coolant yet. Planning on having that setup in the next two weeks with an enclosure. I have a spray bottle of WD-40 and a 60 gallon air compressor for now, along with aluminum chips in every crack and corner! I'm going to air cut first, then wood and then after that try a few different models so that I prove that I have a bit of a handle on it. Build the enclosure, coolant system, upgraded stand and chip collection over the next few weeks then go for more aluminum cuts. I will probably try one or two using aluminum with the air and WD-40 between now and then unless others think I will destroy my end mill trying that....
