You mention this transformer is fed across two phases, this represents a 415 single phase transformer, the star or neutral is not used.
If you want to reduce the secondary, it is usually wound on last, if so you are in luck as you take turns off as needed, and you can calculate as a minimum that there will be around 1.5 to 2 turns/volt.
With a square lamination type it is a bit uglier than doing it on a toroid, but it is possible with care.
Al.
