587,472 active members*
3,073 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Faulhaber Servo Motor and driver , needs CANbus interface to setup , help!
Page 4 of 4 234
Results 61 to 62 of 62
  1. #61
    Apr 2006
    13
    Re: Faulhaber Servo Motor and driver , needs CANbus interface to setup , help!
    Did you use the Motion Manager Wizard to try tune?
    I have not used this yet as i must wait for my CAN bus adapter first.
    In the video you posted... In comparison, my X-Axis, moves much smoother, but still needs tuning.
    I am running from Step/Dir mode. Pusles from Ruida controller.
    How are you controlling the movement in the video?
    My Y-axis does not move.
    What is the "F" command you are referring to? Is it a CAN command?
    If you sending a CAN command I found the Decimal to Hex value a bit confusing in the beginning.
    Examples: (I think/I hope, this is correct...)
    STW 0x77 Value Load Step Width 77 01 00 00 00 01 (01 = LSB)
    STN 0x64 Value Load Step Number 64 50 C3 00 00 01 (50000 Decimal = C350 Hex)
  2. #62
    Apr 2006
    13
    Which version of Motion Manager are you using?
Page 4 of 4 234
  1. Replies: 1
    Last Post: 09-03-2015, 09:38 AM
  2. TB6560 stepping motor driver and 5 AXIS CNC interface board
    By dedikul in forum Stepper Motors / Drives
    Last Post: 02-06-2015, 02:50 AM
  3. Mach 3 interface to stepper motor driver
    By dhookings in forum Machines running Mach Software
    Last Post: 05-28-2014, 05:48 PM
  4. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  5. Omron 500W AC Servo driver for robot setup
    By robo_plasma in forum Servo Motors / Drives
    Last Post: 01-06-2007, 10:28 PM
