587,434 active members*
3,161 visitors online*
Page 4 of 5 2345
Results 61 to 80 of 94
  1. #61
    Jan 2007
    311
    Re: Vista CNC pendant and PP
    Where does PP store program files etc. As in what folders do I need to copy to a USB before I reinstall PP and it wipes out everything?
    M
  2. #62
    Dec 2008
    740
    With the recent flurry of success comments here I decided to try to get my VistaCNC P4S working on PP. I downloaded the latest from Vista CNC (8/23/2016). Things have been updated since I last checked and there are now PP specific instructions. I didn't want to destroy my working control computer so I did everything on another machine setup with the simulation configuration.
    Step 1 says to copy some files to the /home/operator folder. This seemed to work.
    Step 2 says to double click Makefile and select Run. Double clicking opens the file in the editor. Doing chmod +x in a terminal window appears to fix that.
    I then followed the remaining steps including adding a line in the .ini file. Things start but the P4S seems to do nothing other than display "LinuxCNC". Suggestions?
    I just dug out my p2s to see if it would work at all with the p4s binary - I also got the "LinuxCNC" display and nothing worked. I swapped to the p2s binary and replaced all occurrences of p4s in vc-p4s-pp.hal to p2s and my pendant started working. Maybe there's an issue with the p4s binary? You could try installing the p2s binary - perhaps it would come out of the "LinuxCNC" stage - even if other functions might not work. I don't know how compatible the pendants are, but this might be a way to find out if the binary is at fault.
    Using the p2s binary and the modified hal file I've managed to get the jogging, axis zero (for X, Y and Z), estop and machine on/off working. I thought the feed and speed overrides would also work without PathPilot mods but I was apparently mistaken. It appears that the p4s has individual buttons to goto 0 on X, Y and Z. The p2s doesn't have these but they should be easy to get working - if we can get the pendant to work at all!
    By the way, the pendant seems to have an issue when the units are changed to metric in PathPilot.
    Step
  3. #63
    Jan 2007
    311
    So I tried again (why not)
    Launching PP through the desktop and checking the terminal window while it runs shows an error, checked the linux install instructions and noticed there were more instructions to add on a second page that isn't on the pp instructions so I went and added them to the .ini as well.
    Startup goes farther but then stops again, error in the terminal window goes to
    postgui_tormach_mill.hal:166: Pin 'axisui.jog.increment' does not exist
    Error something failed running halcmd on 'postgui_tormach_mill.hal'
    line 166 is the line added per instructions
    net jog.stepsize axisui.jog.increment => vc-m1.jog.stepsize
    if I comment that line out PP will launch but the pendant does nothing at all.
    Do I have to remove (comment out) anything from the shuttle in the hal or ini?
    Does it matter where the lines are added to the hal or ini file?
    M
    now there is a vc-m1 executable copied into the operator dir and there is a vc-m1-pp.hal file copied into the config/mill... dir
    I tried
  4. #64
    Dec 2008
    740
    Quote Originally Posted by Mooser View Post
    M
    I tried
    The Youtube video from VistaCNC showing a pendant with LinuxCNC shows the him using the Axis GUI. The offending line appears to be to be a leftover from this configuration. Commenting it out will certainly not prevent the pendant operating. The files are only initially copied to the operator directory in order to install them. Have vc-m1 and 99-vistacnc-pendant.rules been copied to the directories described in the instructions?
    Step
  5. #65
    Jan 2007
    311
    The files are copied over into the dir's as per the instructions (the install program copied them properly)
    When I commented that line out of the postgui_tormach_mill.hal file PP will load but the pendant does absolutely nothing at all. The power light is on but that's it.
    I'm going to send an email to Vista but since they've not touched anything since last summer I don't think he's too worried about supporting PP.
    M
  6. #66
    Jan 2007
    311
    Well a couple of weeks have gone by with not even a peep from Vista after I emailed with the PP issues and the supplied driver/install issues.
    I gave a complete listing of the exact issues and errors I was seeing as well as the steps taken trying to work around them.
    Guess I was expecting a "we know it's not working and are looking into it" or "thanks for the email" or something.
    I know I purchased the controller to run Mach3 and now I want it to do something different so it's really my problem.
    BUT, if you were looking to buy a controller now and went to the website you would think it ran under Path Pilot since there's drivers and everything there.
    M
  7. #67
    Apr 2013
    1788
    I wonder if the re-flash to Linux mode actually worked correctly. I got an error saying that "validation failed" after the flash. Of course their manual shows the same error as what to associate with success. If I plug my VistaCNC P4S in and then do an "ADMIN HALCMD" followed by "SHOW PIN" the pins for the unit don't appear.
  8. #68
    Jan 2007
    311
    Mine was the same and I also brought that up in my email to Vista (that it said error but matched the instructions)
    M
  9. #69
    Jan 2009
    234
    I also have the Machine Power Off Bug... on The Vista CNC P1AS
    https://youtu.be/uguVMG2F_NM
    Update
    Change This
    # MACHINE
    #net machine-on vc-p1as.machine.on => halui.machine.on
    #net machine-off vc-p1as.machine.off => halui.machine.off
    #net machine-ison halui.machine.is-on => vc-p1as.machine.ison
    To This
    # MACHINE
    Works Good.
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
  10. #70
    Dec 2008
    740
    Quote Originally Posted by Contract_Pilot View Post
    # MACHINE
    To This
    # MACHINE
    Works Good.
    Does the P1AS need the first 2 lines?
    Step
  11. #71
    Jun 2006
    2512
    I'm in the process of upgrading to PP on my 1100 and was expecting to use my Vista P3A pendant with PP until I came across this thread. Have you guys solved the problem, is Vista doing anything useful, or am I back to the shuttle. I can even see the P3A in Vistas' list of none working PP posts. I do have a 4kg lump hammer that would provide a fix.
    Regards
    Phil
    PS: You guys have been extraordinarily patient over the past 2 1/2 years, I'm impressed.
  12. #72
    Aug 2014
    257
    Quote Originally Posted by philbur View Post
    Yeah, I have a Vista Pendant sitting in my drawer too. It was very disappointing that it wouldn’t work with PP. I tried in vain to get it working with the help of Vista, but no joy.
    So I finally got the shuttle instead & the funny thing is I like it better than the Vista Pendant!
  13. #73
    Jun 2014
    1780
    Quote Originally Posted by rdsi View Post
    I have a Vista pendant that isnt used, I emailed them and got no response when I converted to pathpilot. I really like the shuttle better, just personal preference.
    mike sr
  14. #74
    Apr 2013
    1788
    I too have a Vista pendant stored in a drawer. The Shuttle works fine but with two issues for me: no convenient way to zero an axis for setup and it is definitely not resistant to aluminum chips (my replacement just arrived from Amazon).
  15. #75
    Jun 2006
    2512
    I see that the latest download date for the Vista PP (Linux) driver is May 2017. Has anybody tried this revision, it has specific instruction installing to PP.?
    Phil
  16. #76
    Jan 2009
    234
    I have had mine working for some time....
    https://youtu.be/n0YpBLKKRyQ
  17. #77
    Jun 2006
    2512
    Great, thanks for the feedback . More information/background would be useful. For example do all functions work?
    Phil
  18. #78
    Apr 2013
    1788
    The installation notes for the P4S (my unit) say that feed override, spindle override, cycle start, pause, cancel, spindle on/off and eStop don't work. Those seem to be rather important omissions! I don't understand about eStop since that is a hardware button rather than anything software related and actually works without installing any updates so I have limited confidence in anything that they say.
  19. #79
    Jun 2006
    2512
    Thanks for the feedback. I guess that identifying the none working functions in the installation notes allows them to claim it is a driver for PP. A more honest approach would have been to have identified them up front on the web site, not in a document you read after you have purchased the device.
    Vista have told me they have no plans to provide a driver for the P3A (my pendant) so I was considering to buy one of the S models, but not now, not after reading your last post.
    Isn't it time that Tormach came up with a purpose built MPG pendant?
    Phil
  20. #80
    Apr 2013
    1788
    Cost is one advantage of the current approach. The z-axis select button for my Tormach shuttle became very flaky and I was able to buy a ShuttleExpress on Amazon for less than Tormach's price and with free shipping. Of course a sealed pendant would have been even better!
    That said, I would love a shuttle replacement with axis zero +axis display + sealed +... Didn't PENTEC have something working?
Page 4 of 5 2345
  1. Help with NT and Vista
    By mreichle3760 in forum Community Club House
    Last Post: 01-19-2014, 04:21 AM
  2. Vista or XP ?
    By Farmers Machine in forum CamSoft Products
    Last Post: 10-25-2008, 11:58 AM
  3. MC 9 In Vista
    By phoodieman in forum Mastercam
    Last Post: 03-24-2008, 03:35 AM
  4. Is anyone using V19 with Vista OS?
    By Fleck in forum BobCad-Cam
    Last Post: 01-28-2008, 02:38 PM
  5. MS Vista?
    By prototect in forum Mach Software (ArtSoft software)
    Last Post: 02-24-2007, 11:31 PM
