587,850 active members*
2,979 visitors online*
Thread: BT30 Spindle
Page 29 of 29 19272829
Results 561 to 570 of 570
  1. #561
    Sep 2006
    6463
    Re: BT30 Spindle
    It's gone awfully quiet again.....did you get any joy with the grinding of the slots?
    I think you could have done the job initially with an angle grinder mounted in a stand and plenty of water to keep it cool, then tidy it up with the diamond wheel afterwards......it won't be easy.
    Ian.
  2. #562
    Mar 2014
    1132
    Re: BT30 Spindle
    Hi Ian,
    I didn't touch the spindle since then. I'm a little busy these days. I'll keep you posted tho.
    Suat
  3. #563
    Sep 2006
    6463
    Re: BT30 Spindle
    Hi, yes I know what you mean, time for everything is a wish list item......just very interested to see the ongoing design as it materialises.
    Ian.
  4. #564
    Jul 2019
    8
    I feel that no matter what problems on the steel, you can find Songshun to help you answer. Because they have patiently answered my question.
    Contact: https://steelpurchase.com/about-culture/
  5. #565
    Re: BT30 Spindle
    azalin
    can you post the cad models I just want to have a look at them. Step would work best but just do what is easiest for you. you may have posted it earlier and I made an attempt to find it but then i saw all 47 pages of this and I gave up(got to around 20). If the designs are not finalized post them anyways I am very interested in the design of these thing and would like to design my own and it makes it a lot easier when you have a reference even an unfinished one. Thanks.
  6. #566
    Re: BT30 Spindle
    Did I not complement the amount of work and skill that has been pumped into this project? I didn't. Anyway this is an amazing project with a huge amount of work and skill pumped into it.
  7. #567
    Mar 2014
    1132
    Re: BT30 Spindle
    No, sorry!
  8. #568
    Mar 2014
    1132
    Re: BT30 Spindle
    As I finished my BF20L conversion this spindle finally found his home machine.Attachment 475906
    Sent from my MI 5s Plus using Tapatalk
  9. #569
    Sep 2006
    6463
    Re: BT30 Spindle
    Hi, all good things come to pass with patience.
    After 35 years of it standing in the corner of the garage I had a great need for a mill so I bit the bullet and did a jig borer conversion.
    I've just completed the conversion and had to cut the end off of the spindle to fit an ER32 collet chuck to the end of the spindle as it previously had a 2 Morse being it started life as a jig borer...........then I raised the column up 100mm with a spacer to get more Z room for drilling etc..........finally I fitted a 3 axis DRO and that is really what makes it come to life......no more marking out holes for me.
    I think a mill without a DRO is like going to a dance in your undrerwear.
    Ian.
  10. #570
    Nov 2020
    361
    Re: BT30 Spindle
    hey Azalin
    how did you go about the junction between the end of the drawbar and the end of the shaft?
  1. Bt30 or bt40 spindle
    By KKamel in forum Spindles / VFD
    Last Post: 12-14-2015, 10:03 PM
  2. BT30 Spindle Help
    By Momentz in forum Benchtop Machines
    Last Post: 11-03-2015, 01:08 AM
  3. Looking for a BT30 Spindle
    By xtwalt in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2012, 10:10 PM
  4. BT30 Spindle
    By dirtridn2010 in forum Tormach Personal CNC Mill
    Last Post: 05-07-2012, 11:19 AM
  5. Reasonably priced BT30 ATC spindle.
    By dwalsh62 in forum News Announcements
    Last Post: 05-12-2011, 05:59 PM
