The photo dedeer posted is a TBR20 support block, rather than the usual SBR20. The TBR's wider buttresses should help prevent the bearing shell from opening up under tensile loads. Do they work? I don't know, but I'm planning to test the stiffness of some TBR and SBR blocks to see. My guess is it'll only be a modest improvement, since the bearing shells are the same and only have 1 off-center ball-track for tension.
