587,421 active members*
3,356 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Optimum BF20L CNC conversion using the Smooth Stepper
Page 20 of 31 10181920212230
Results 381 to 400 of 602
  1. #381
    Jun 2011
    I'm curious here guys if my coolant pump works by pumping a large mass of coolant rather than a large operating pressure. My hose from the pump to the nozzels fitted on the machine has a 4mm ID, and so I'll pick up a 6mm or slightly larger hose tomorrow and see if the larger diameter will increase the flow as it doesn't appear to be as powerfull as I first thought before I extended the housing.........and hopefully all going well tomorrow I should be able to get a small video of the flood coolant operating during a run.
    Eoin
  2. #382
    7063
    Coolant pumps are, generally, NOT high pressure. They are high flow. If you want an inexpensive high pressure pump, buy a shallow well pump, which will develop about 60 PSI, and can be bought for about $125.
    Ray L.
  3. #383
    Jun 2011
    Yeah cheers for that Ray I kinda figured that it's like with weld fume extractors you can get them high volume extraction or high pressure extraction.
    Eoin
  4. #384
    Jun 2011
    Well the coolant hose ID made an incredible difference, I changed the 6mm (¼inch) to 8mm (5/16inch) with respective tail fittings and I recorded a part being machined….but ha I couldn’t upload it all cause it’s over 5GB for a 34min recording…… ha didn’t realise that the video on the phone recorded HD…. so I trimmed 8sec off and uploaded that, and that’s still 16MB though, I’ll run off another part tomorrow and reduce the video quality settings….
    I must now start the belt drive and for those of you who have the belt drive completed bet your not sorry when you hear the noise of my stock gears running...
    [ame=http://www.youtube.com/watch?v=MhzGBc7XAfw]Flood Coolant - YouTube[/ame]
    Eoin
  5. #385
    Jun 2011
    Sorry all just to correct my last post....I should have said that I changed from a 4mm ID to an 8mm ID coolant hose and fittings......
    and here’s a question a bit off topic guy’s…..I can download a HD YouTube video @ 1.7MB per sec, but it took 1hr and 45mins to upload only 210MB of HD video, anyone venture a guess here???
    As I’m not a machinist and only a humble Welder, and learned all this CNC hobby from you guy's and I’ve learned another lesson here with this little project, that one should always lower the feed rate when running a finishing pass…..i.e. when inputting your speeds and feeds into your chosen CAM software DON’T use the same feed rate that you use for the roughing pass like I did here, even though your depth of cut (DOC) is minimal …….and this is evident in the photo below as you can see quite clearly see the vertical cutting lines on the fins of the water coolant fan……
    Eoin
  6. #386
    1943
    I would venture a guess that your download speed was 1.7 mega bits per second, and not mega-bytes. 1.7 megabits per second is about 200 kilobytes per second or .2megabytes per second. At that rate, it would take about 15 minutes to transfer 210 Mbytes, but internet service generally has much faster download speed than upload speed. Also video uploaded to Youtube automatically gets converted which slows things down.
  7. #387
    1943
    Also, your pump impeller looks fine. Don't sell yourself short as machining is something that doesn't come overnight. You have done a great job on your machine and the machining aspects will come over time. Machining is one of those things where you never really know everything about it.
  8. #388
    Quote Originally Posted by Mad Welder View Post
    Pretty is nice but they don't all have to be as long as it does the job for you.
    Practice makes perfect, good work.
    Hoss
  9. #389
    Jun 2011
    Thanks for the kind words.......and the internet explanation
    Eoin
  10. #390
    Jun 2011
    O
    Eoin
  11. #391
    Jun 2011
    At last I have started on my belt drive conversion........ My lathe chuck is only a 4"so I had to remove some stock first
    Attached Thumbnails Attached Thumbnails 2012-07-27 22.48.48.png   2012-07-27 22.49.24.jpg   2012-07-27 22.50.01.jpg   2012-07-27 22.50.36.jpg
    Eoin
  12. #392
    Jun 2011
    Today went well I managed to finish off the two pulley blanks
    Attached Thumbnails Attached Thumbnails 2012-07-28 18.08.54.jpg   2012-07-28 18.11.15.png   2012-07-28 18.12.42.png   2012-07-28 18.11.44.jpg
    Eoin
  13. #393
    Jun 2011
    Almost finished the motor/spindle head mounting plate......ordered my pulley belt this evening (L belt type) from SDP so hope to get it next week sometime......got a question too here guys slightly off CNC topic, what's the best paint for a workshop floor? and this is going on bare concrete too.....
    Attached Thumbnails Attached Thumbnails 2012-08-01 22.53.18.png   2012-08-01 22.52.23.jpg   2012-08-01 22.55.56.jpg   2012-08-01 22.56.35.jpg
    Eoin
  14. #394
    7063
    About the only paint that will hold up on a floor is a real solvent-based (NOT the newer water-based stuff) epoxy floor coating. This is neither cheap, nor easy to apply. Doing it properly requires doing a very thorough cleaning with soap, water, and a lot of scrubbing, followed by a good acid etching. Dry completely, then epoxy. Figure on AT LEAST $1/sq. ft. total cost. If the concrete does not have a decent vapor barrier under it, the coating may still lift off over time.
    Ray L.
  15. #395
    Jun 2011
    Yeah I guessed it wouldn't be easy but I figured I'd only paint from the Mill and Lathe .to the wall, not the whole shop floor...geez tis too big and way over my budget
    Cheers for that Ray
    Eoin
  16. #396
    Jun 2011
    Here's a suggestion for your secondary filter on your coolant systems me I'm using a coffee perculater filter........
    DIY CNC Flood Coolant Filtration - YouTube
    Eoin
  17. #397
    Jun 2011
    695
    Great idea on the filter...I actually have on in stock so I will copy that idea for sure.
    Epoxy floor paint
    Epoxy coat has some great reviews but is pricey.
    Not sure what big box hardware stores you have but I used Rustoleum epoxy oil base on mine and am really happy with it. One gallon kit was around $100 US.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  18. #398
    Jun 2011
    Quote Originally Posted by FannBlade View Post
    Epoxy floor paint
    Many thanks for the reply and I'm really sorry to hear of your dad passing, I know ye were close, and good friends, my prayers and thoughts are with you and your family at this time.....
    Eoin
  19. #399
    Dec 2007
    2134
    This is a great link to a decent video of Chris from the geek group applying epoxy. I'm planning the same when my workshop is finished.
    [ame=http://www.youtube.com/watch?v=7OYsOHIKNVE&feature=plcp]How to Paint Your Floor With EpoxyShield - YouTube[/ame]
    cheers,
    Ian
  20. #400
    Jun 2011
    695
    Thanks. You have been a great online friend. I'm still jealous of the great progression you have made on your build! (wedge)
    Quote Originally Posted by aarggh View Post
    cheers,
    Ian
    Yep that's the stuff!
    Hurco KMB1 Build
    C-Constant
    N-Nonworking
    C-Contraption
  1. Optimum 180x300 CNC Gang tool conversion
    By belli in forum Mini Lathe
    Last Post: 11-25-2015, 10:51 PM
  2. Optimum BF20 G0704 Conversion
    By Winnfield in forum Benchtop Machines
    Last Post: 08-07-2011, 12:16 AM
  3. Smooth stepper
    By dnelso in forum Charter Oak Automation Support Forum
    Last Post: 08-04-2009, 05:07 PM
  4. Optimum BF20L CNC conversion
    By JanHenning in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2009, 05:09 PM
  5. OPTIMUM BF20L mill, z-travel exactly from table height ?
    By vroemm in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2009, 10:01 PM
