587,421 active members*
3,217 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach 1100 Passive Probe Calibration Issue.
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Aug 2009
    610
    Re: Tormach 1100 Passive Probe Calibration Issue.
    I am glad that you are good to go now. Excellent! BTW you will be chasing the probe adjustment screws around forever to get rid of error using the tormach screw turn method. I did it once and thought wow this is stupid. Using an indicator is the only way to nail it. I dialed it in using the same procedure that I used for my Haimer probe and was much happier with the results. If you can keep the passive probe clean they will serve you well- oh yeah and don't break the tip off like I have done several times. Stupid chips and coolant in the jog shuttle can make axis moves a little quicker than you anticipate :-).
  2. #22
    Jun 2006
    340
    Quote Originally Posted by pickled View Post
    Hi pickled,
    What is the procedure you use for probe calibration using a DTI/dial indicator?
    Bevin
  3. #23
    Dec 2006
    302
    I just put a 3/4" collet in my lathe, inserted the probe, put a high quality test indicator on the compound and centered the probe tip.
  4. #24
    Jan 2013
    630
    I'm not sure the Tormach probe offers this but I have a connector right off my probe so that the cable can be disconnected and allow the probe to rotate freely with the spindle. I simply mount it in the spindle, unplug the cable and the set a .0005 dial indicator on a mag base via the table and adjust until I get zero run out. The adjustment screws on mine are very sensitive so it can take a little bit to get it right but once there it's good until I jam it into something and break a tip.
  5. #25
    What speed to you guys probe at? I have been testing from 5 to 20IPM. Not sure what is best.
    Donald
  6. #26
    Jun 2006
    340
    I am surprised that the probe doesn't dislodge with the pressure of the DTI point. Must try it.
    Thanks.
  7. #27
    Jan 2013
    630
    Quote Originally Posted by dneisler View Post
    35 on the first and 25 on the second tap.
  8. #28
    How do you tell a torch two different speeds? I have only seen the one box that changes it.
    Donald
  9. #29
    Jan 2013
    630
    I'm not a Tormach owner. I run Mach 3 with the MSM screen sets. It allows for a slower second probe speed.
  10. #30
    Ahh, I actually installed MSM on my Torch over the weekend and got the free version working. I like it so far, but I have not done much or even machined anything yet with it.
    Donald
Page 2 of 2 12
  1. Tormach Passive Probe.
    By JohnToner in forum Tormach Personal CNC Mill
    Last Post: 01-25-2015, 06:15 AM
  2. Tormach Passive Touch Probe issues in metric (G21)?
    By mooreaa in forum Tormach Personal CNC Mill
    Last Post: 11-15-2013, 02:48 AM
  3. Tormach passive probe setup.
    By mrquacker in forum Tormach Personal CNC Mill
    Last Post: 05-30-2013, 03:41 AM
  4. Tormach Passive Probe - anyone tried it?
    By Jeff E. in forum Tormach Personal CNC Mill
    Last Post: 09-28-2012, 06:12 PM
  5. New Tormach Digitizing Probe Calibration Update
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 08-09-2012, 10:51 PM
