587,366 active members*
3,665 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > Need help with g code for fire control pocket on AR15 lower reciver, have G code.
Page 2 of 3 123
Results 21 to 40 of 52
  1. #21
    Jan 2006
    2985
    Sorry for the radio silence, real life has been calling.
    I picked the X,Y zero to be the front and center of the pocket. You can locate that off the mag well and/or the bolt catch slot with dimensions from a drawing.
    I've labeled each endpoint of every segment along the toolpath. I propose to start at point A as it will not touch the final surface at that position so any funny marks from plunges or dwells will not affect the final finish.
    The next step is to find the coordinates of all of these labeled points. Anyone care to give it a shot? It is just basic addition and subtraction using the given dimensions...
    Edit: BTW, I am using CAD to make all this but pen and paper is equally effective. I am using CAD as it is a lot easier to make a legible copy ready for upload.
  2. #22
    Feb 2009
    2143
    Damn... If they OP can't respond to this, you are wasting your spoonfeeding....
    Oh, wait, he hasn't been back in the thread since the post! People are f'ing lazy...
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  3. #23
    15362
    mcphill
    The OP got his machine setup & made the part within 2 days of posting, I don't think he has had the need to come back
    Mactec54
  4. #24
    Jan 2006
    2985
    My effort was directed at thisdjj. Hopefully he responds.
    You see now why no one wants to waste their time with these people...
  5. #25
    Jan 2014
    13
    I'm sorry Keebler I will try this tomorrow been real busy at work and won't have a day off until tomorrow
  6. #26
    Jan 2006
    2985
    Quote Originally Posted by thisdjj View Post
    No need to apologize as long as you're still listening. Time and time again people ask a question, get their answer and then disappear into the woodwork.
  7. #27
    Jan 2014
    13
    I thank you for your time and it will not be in vane
  8. #28
    Jan 2014
    13
    So I've been looking at the drawing and would like to know what points do you need the math for I'll be more than happy to do it for the learning experience as well as you helping me
  9. #29
    Jan 2006
    2985
    The easiest way to program a toolpath is with centerline programming, that meaning you program the path that the center of the tool will take. Each line of G code moves the tool from one point to another point. These points are the ones I have labeled A,B,C,etc. You need all of them to write a program. I'd suggest an excel-like table with point label, X coordinate and Y coordinate listed out, you can do it on a piece of paper or something too but if you keep it digital it is easier for others to check your work. I have already given you point A in the drawing.
    Matt
  10. #30
    Jan 2006
    2985
    :bs:
  11. #31
    Jan 2014
    13
    Quote Originally Posted by keebler303 View Post
    :bs:
    Actually Keebler I have been taking a class to learn that's why I haven't been on here
  12. #32
    Jan 2006
    2985
    If you choose not to complete the exercise I have presented then my efforts were indeed in vain. Regardless, I am glad you are making an effort to learn something.
  13. #33
    Jan 2014
    13
    I do appreciate it but as far as my experience I have none and couldn't figure out the exercise you wrote
  14. #34
    Jan 2006
    2985
    You didn't ask any questions. If you cannot figure out adding and subtracting numbers or plotting in 2D, you are going to struggle in any "class" you sign up for. If you made an effort I would be willing to help further, sadly, none was made...
    Good Luck
  15. #35
    Jan 2014
    13
    You are right I took a look at it printed it out and couldn't figure start to finish points for the math and had just figured to try and get some help that's why I signed up for the class.
  16. #36
    Jan 2006
    2985
    The location I marked on the drawing as the origin is the place where X = 0 and Y = 0. You will move your machine until the center of the spindle is at that point and then zero the X and Y axes so the machine reads (0,0) when it is at that point.
    To get to point A (where we want to start cutting) we have to move 1.8925" in the negative X direction and .0005" in the negative Y direction. These numbers are ones I already provided for point A.
    To find these coordinates, you just need some addition and subtraction.
    For the x coordinate of point A, we will take the given length of the slot (2.080") and subtract the radius of the tool (we already decided on a 3/8" diameter endmill).
    2.080 - 0.1875 = 1.8925". Since it is left of zero, it should be negative so -1.8925 is the coordinate we need. It is better practice to always add when you move from left to right and subtract when you move right to left. The proper math is:
    0 - 2.080 + 0.1875 = -1.8925"
    For the Y coordinate it is a bit more math but still straightforward. Starting at zero, we will go up .345 (half of .690) which is the distance from zero to the top of the pocket. Now we go down 0.095 to get to the top of the smaller left pocket, go down another 0.438 for the width of that pocket, then finally we add the tool radius back on.
    0 + 0.345 - 0.095 - 0.438 + 0.1875 = -0.0005"
    Now we have the coordinates for point A (-1.8925,-0.0005)
    Moving on to point B, Same deal, just add and subtract to get there, I'm not going to hold your hand...
    For X: 0 - 3.512 + 1.080 - 0.1875 = -2.6195"
    Y is obviously the same value as for point A, it is a straight line.
    Point B is (-2.6195, -0.0005)
    So now we are well on our way...
    A (-1.8925,-0.0005)
    B (-2.6195, -0.0005)
    This will be my last post in this thread until some brain power is expended...
  17. #37
    Jan 2014
    13
    I'm going to print this out so that I can study and understand it thank you
  18. #38
    Jun 2006
    7
    Re: Need help with g code for fire control pocket on AR15 lower reciver, have G code.
    Hi keebler303, allow me to pick up the slack. I want to learn this. So D is 0.1875 from the lower edge, the width of the part is 0.500 assuming center line splits it symmetrically (judging by the fact that you didn't leave any measurements to show otherwise.. we have an Y for the D at - (0.25 - 0.1875) = - 0.0625, now X is a bit funky for me, correct me if i'm wrong it says Radius of the curve is at 0.218, so it should be 0.218 from D to the right edge of the cut, the cut is at 0.1875 from B on X, so for D, X= -2.6195 - (0.218 - 0.1875) = -2.65. So final result for D (-2.65, -0.0625). Now for C, X is the same as for B since it is a straight down path, but Y = -0.0005 - 0.062/2 = - 0.0315, so the final answer for C(-2.6195,-0.0315)
    Am I on the right track, just want to confirm before continuing.
    And thank you for doing it. I'm sure it will help a lot of noobs out here, me inclusive.
  19. #39
    Jan 2006
    2985
    Coredump
    Thanks for coming.
    I wouldn't assume anything on a drawing. I previously mentioned that my origin (0,0) is centered on the .690 dimension in the Y axis, so I'll go off that.
    Y for point D goes like this: 0+(.690/2)-.095-.5+.1875 = -.0625 Looks like your ASSumption was ok.
    X for point C goes like this: 0-3.512+1.0800-.1875 = -2.6195
    The difference between Xc Xd and Yc Yd should be the same since they are on an arc 90 degrees apart. To figure it out, I subtracted the tool radius from the big radius: .218-.1875 = .0305
    Xd = Xc-.0305 = -2.6195-.0305 = -2.6500
    Yc = Yd+.0305 = -.0625+.0305 = -.0320
    So your Y coordinate for C was a bit off, this is why: If you start at your assumed centerline, which is at Y=0, then your Yc should be 0-0.062/2 NOT -0.0005-0.062/2. That gives you Yc = -0.0310. That is not what I just calculated above so what is going on? I checked my drawing and the two radii on either side of the .062 are actually .219 radius and not .218. To make things easier, lets just make all the radii .218. If we do that, the .062 dimension grows to .064. Just cross out the.062 dimension on your copy and make it 0.0640. Now Yc = 0-0.064/2 = -0.0320. We got it!
    Keep up the good work
    Matt
  20. #40
    Jan 2006
    2985
    One note about working with numbers:
    If you are working to 4 decimal place accuracy, you should state all your numbers to that accuracy. If you don't, it is hard to tell if 1 is actually .9900 rounded, or if you just typed the 1 and forgot to enter the rest of the number. If you see 1.0000 then you KNOW it is 1 for sure.
    It is a good habit to get into to help avoid errors and mistakes.
Page 2 of 3 123
  1. milling an AR15 lower..
    By opcode1300 in forum Gunsmithing
    Last Post: 10-27-2018, 11:23 AM
  2. First Tormach Project - AR15 Lower
    By s2jesse in forum Tormach Personal CNC Mill
    Last Post: 01-25-2014, 09:12 PM
  3. Lower case letters in G-code
    By imachining-6061 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-25-2013, 01:16 PM
  4. G-Code for turning a AR15 barrel from blank
    By Gtrigg in forum G-Code Programing
    Last Post: 09-11-2011, 06:27 PM
  5. Replies: 4
    Last Post: 03-30-2011, 12:42 PM
