587,255 active members*
3,222 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > v1.9.2 is out... who volunteers to be the guinea pig?
Page 2 of 2 12
Results 21 to 38 of 38
  1. #21
    Feb 2015
    34
    Re: v1.9.2 is out... who volunteers to be the guinea pig?
    Not a problem with the disable setting and still works fine when I go back to 1.9. I had the same problem when I first got the mill and Tormach had me swap some of the limit switch wiring. It's just weird that after two other upgrades it now has a problem with this one. Also the Y and Z are fine.
    Sent from my SM-N900V using Tapatalk
  2. #22
    Jul 2003
    1754
    Could it be
    The discrepancy was the door switch in the settings column setting, uncheck it and the machine will reference fine.
    I assumed they meant the spindle door.
    What Tormach meant was the full enclosure door switch not the spindle door switch..
    from
    http://www.cnczone.com/forums/tormac...on-1-91-a.html
  3. #23
    Feb 2007
    1538
    Yes - I bet its your door switch checked. - A new feature in 1.9.2 Keen
  4. #24
    Feb 2015
    34
    Ok so I reloaded 1.9.2 and z and y are fine but when I reference the X axis it hits the limit switch and the door light comes on as it is still trying to travel.
    Time to dig out the wiring diagram.
  5. #25
    Feb 2007
    1538
    Did you uncheck your doorswitch in that page? Keen
  6. #26
    Feb 2015
    34
    Quote Originally Posted by keen View Post
    I have now and that fixes the referencing problem but what about the door safety?
  7. #27
    Jun 2014
    1780
    Quote Originally Posted by SPRSkip View Post
    The "door safety" check box is for the new enclosure they are selling, not the door safety on the machine, a bit confusing.
    mike sr
  8. #28
    Feb 2015
    34
    Quote Originally Posted by popspipes View Post
    Ahh IC
    New problem, I have no coolant,
    pump is working fine when plugged into wall outlet
    button on screen lights up and I can hear a relay working when I click the button
    using M8 lights the button on screen
  9. #29
    Feb 2015
    34
    Ahh IC
    EDIT
    OK so after re connecting the coolant pump and cycling on and off a few times it is working.
    Relay going bad?
  10. #30
    Jun 2005
    656
    Could be the pump is getting gunked up and hard to start too. They do that after a while with some coolants and it will behave just like this.
  11. #31
    Feb 2015
    34
    Quote Originally Posted by shred View Post
    Good idea but I did check the outlet and there was no power
  12. #32
    Dec 2013
    267
    I had an issue with my original PCNC1100 pump where it would "buzz" very lightly, it was because it was gunked up with coolant after having not been run for a week. After a few go arounds of popping it apart and twisting the shaft with pliers, I ended up replacing it with Tormach's "high quality" 1/8hp pump (vs 1/10hp original) and haven't seen any issues since. The new pump is quite a bit more powerful and definitely fills the locline with no problem. I run the locline without the nozzle at the end to get more coolant on the part and keep chips flushed out.
    If you're sure it's a power issue, you might need to check your fuses inside your electrical cabinet. They are called out on the wiring diagram.
    Good luck!
  13. #33
    Mar 2012
    51
    I finally updated to v1.9.2 and all is well, except, my Jog % is 40% every time I restart. Does anyone know how to change this by default? I had a brief look in some of the files in the TMC/config folder, but no luck.
    Adam
  14. #34
    Aug 2013
    980
    Tormach does this on purpose since it is easy to crash a probe/tip/tool at 100%
    This was explained to me on the phone
    Quote Originally Posted by adamboon View Post
    Adam
  15. #35
    Jun 2014
    1780
    The only anomaly I have lately is the "P word with a G 81 or 83 move, it will be ignored" error that sometimes is in the Sprut 7 posts, PathPilot ignores it but it still produces an error message.
    mike sr
  16. #36
    Mar 2012
    51
    Quote Originally Posted by CadRhino View Post
    Thanks for the info. I guess I'll just have to manually slide it up to 100% every time I start up PathPilot.
    Adam
  17. #37
    Jun 2004
    6618
    I think it is a pain, however most things that save our ass are. I only need to deal with it once every job. It is acceptable then.
    Lee
  18. #38
    Mar 2013
    23
    Adam
    Someone showed me that if you hold shift (I think) while hitting the arrow keys it will rapid instead of moving that the reduced rate.
Page 2 of 2 12
  1. .STL to .DXF Conversion - Guinea Pigs Needed....
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 05-25-2016, 09:25 AM
  2. Im gonna be a Harbor Freight guinea pig ....
    By sunnyday in forum Mini Lathe
    Last Post: 11-09-2009, 11:28 PM
  3. any volunteers???
    By turmite in forum BobCad-Cam
    Last Post: 01-09-2004, 08:25 PM
