Originally Posted by
redcobra
biggest problem is lack of safety when using camsoft and galil. If the pc goes into blue screen and the axes are going somewhere it wont stop
That is not necessarily true. I am not aware of all the implications under Camsoft, but the Galil card operates to a great extent as a stand alone, it just uses the buss for communication and power, the BSOD is a Windows crash, the PC for the majority of cases is still operating, Galil does not need Windows to operate, the fact that it will run perfectly fine in DOS is a testament to that.
My experience is if the Galil has not recieved a reset it will complete the move that is in its memory. If the Galil sees a voltage error on the bus it will shut off.
Al.
