587,669 active members*
3,814 visitors online*
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Apr 2011
    20
    Re: Shizuoka AN-S
    I do not have a source for one. I planned to measure/engineer one and then machine it. I'll make several when/if I get it done. I would appreciate the opportunity to buy one if someone else goes through the exercise. Measurements of a good one would be very much appreciated, too.
  2. #22
    Mar 2015
    Re: Shizuoka AN-S
    How did you pull the Y axis ball screw? Did you have to remove the knee? I am rebuilding the X/Y axis on a Shizuoka AN-S mill. Thanx!!
  3. #23
    Apr 2011
    20
    Re: Shizuoka AN-S
    So my belt finally popped! It seems like I have to wind the screw that moves the yoke for the variable width pulley all the way out and then the variable pulley assembly should pull all the way off. Happily it seems to have slid off the end of the splined shaft down into the gearbox. I too have sheared the nylon back gear if anyone has a source. I fear I'll have to reverse engineer it and machine one... It figures I broke the belt an hour after everyone closed for the weekend.
  4. #24
    Feb 2012
    Re: Shizuoka AN-S
    Nice machine. Nice servo drives. Absolute bargain.
    - - - Updated - - -
Page 2 of 2 12
  1. Shizuoka B-3V help
    By petek in forum Uncategorised MetalWorking Machines
    Last Post: 12-07-2021, 03:18 PM
  2. Need help Shizuoka
    By elmeys in forum Uncategorised MetalWorking Machines
    Last Post: 01-03-2020, 05:42 PM
  3. Shizuoka
    By ozzie34231 in forum Knee Vertical Mills
    Last Post: 06-14-2018, 01:00 PM
  4. Shizuoka Cnc An-s
    By SHIZUOKA in forum CNC Tooling
    Last Post: 10-27-2011, 05:15 PM
