587,138 active members*
3,782 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Stripped the column cap head screws on g0704
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Re: Stripped the column cap head screws on g0704
    I actually watched the video before I posted. A quick search turned it up.
  2. #22
    Oct 2017
    17
    Quote Originally Posted by 109jb View Post
    It sounds as if the hex that the allen wrench fits into is what is stripped. If that is the case then the bolt will still be under terrific torque.
    That's what I'm scared off. I was thinking of using a dremel tool and cut off the Screw head. But since it's under torque might not be a good idea.
    I was thinking because there are two other screws that are fine they will hold the column in place and I'll use a left hand drill and then a screw extractor to avoid having the bolt head pop off and fly out like a bullet.
    Do you think an m12 screw can be extracted using a screw extractor of the right size?
    - - - Updated - - -
    Just for reference, these are the bolts the OP is talking about
    Attachment 422902
    Yup these are the screws I'm trying to get at.
  3. #23
    Oct 2017
    17
    I'm afraid I might just have to buy a new column and bar which is around 400 together. I guess I have to pay for my stupidity.
    I was trying to tram the column, I was noticing
    .001 deviation in the y-axis so I was tightening and loosening to get it right.
  4. #24
    You are vastly over estimating the amount of force the heads of those bolts will have once drilled off. They won't even release in an instantaneous manner, they will deform and loosen before fully drilled.
    There is nothing dangerous about drilling those bolt heads off. Stop being dramatic. Get your drill out, get a drill bit, and remove them.
  5. #25
    1943
    When you drill the head of a bolt off you gradually reduce the cross section that is still holding the tension. As you get closer and close to breaking through the tension will release gradually and you won't even notice that the bolt was under tension once off. That part won't be a problem.
    As far as a screw extractor being able to do it, yes a big enough screw extractor will take one out . They get tighter as you try to loosen the bolt. Those extractors that I linked are not "normal" screw extractors, but have a shorter spiral section, a faster spiral and don't need as much depth as a "normal" extractor. They work really well on SHCS. I have a set of them. You can probably use a regular screw extractor, but the hex hole might not be deep enough as those need some depth to get a good grab.
  6. #26
    Jan 2018
    1516
    Quote Originally Posted by CL_MotoTech View Post
    I'd use Cobalt drill bits on those. basic HSS take me forever.
Page 2 of 2 12
  1. Had a weird problem pop up after replacing my column on G0704
    By skyguynca in forum Benchtop Machines
    Last Post: 12-14-2017, 06:52 PM
  2. G0704, Too tight Column Bolts
    By rrangana in forum Benchtop Machines
    Last Post: 05-26-2014, 12:01 AM
  3. WTB: Used Square Column Mill Washington / Oregon G0704, PM25MV, or PM30MV!
    By Contract_Pilot in forum Want To Buy...Need help!
    Last Post: 01-18-2014, 06:21 PM
  4. G0704 column bolts?
    By exitium in forum Benchtop Machines
    Last Post: 03-04-2013, 01:35 AM
  5. Column gibb is binding on g0704
    By Nada mucho in forum Benchtop Machines
    Last Post: 02-02-2012, 01:27 PM
