587,546 active members*
3,810 visitors online*
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    ericks Guest
    Re: Delta vfd settings
    I will start sending you what i think you should set and we will see how it goes....but please disconnect the motor cables
  2. #22
    ericks Guest
    Some of the settings may be changed later....
    1) 00-09 = 00
    2) 01-00 = 400
    3) 01-01 = 400
    4) 01-02 = 380
    5) 01-05 = 0.......for testing, we will change it later before we connect the motor
    6)
  3. #23
    ericks Guest
    oops...i seem to have lost my last post with more parameters
  4. #24
    ericks Guest
    I am going to make a spreadsheet with the parameters
  5. #25
    ericks Guest
    I might have missed a few but i think i got most of the important ones...
  6. #26
    15362
    Something wrong can't post Parameter list that you need to this thread PM me your email if the PM is working for you and I will send you what you need
    Mactec54
  7. #27
    Dec 2017
    13
    Quote Originally Posted by ericks View Post
    Hello, sory for late replay,had some healt ishues. Thank you for the parameters i will try it first thing in the morning and hope it will work.
  8. #28
    ericks Guest
    Quote Originally Posted by Deluk View Post
    Hi....sorry to hear about your health issues, hope you feeling better
  9. #29
    Jun 2006
    198
    Quote Originally Posted by AdminCrew View Post
    I have a Delta VFD-B VFD on my little green thing in the shop, Is autotune a good idea, or can it do more harm than good?
    And if it does good, is there a specific way to do it?
  10. #30
    15362
    Quote Originally Posted by IN-WondeR View Post
    You need all the main Parameters set for your Motor / Spindle before you can use auto tune or it will be messed up and have wrong settings
    Mactec54
Page 2 of 2 12
  1. Delta Servo Motor 750 W and Delta ASDA-B2 drive setup issues
    By johnansaro in forum Servo Motors / Drives
    Last Post: 03-02-2018, 06:16 PM
  2. Delta VFD EL 2.2KW settings
    By vakeiros in forum Spindles / VFD
    Last Post: 04-04-2017, 10:16 PM
  3. Wye-delta, delta-wye configurations?
    By mackeym in forum Phase Converters
    Last Post: 07-06-2016, 10:26 PM
  4. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  5. delta tau
    By Jeremiah in forum Servo Motors / Drives
    Last Post: 06-23-2006, 01:41 AM
