It's not that I didn't know that there would be cleaning and maintenance involved in owning my 770 mill. I fully expected it but, it's the fact that cleaning my mill after I used it actually added to the wear and tear of the machine rather than mitigating some of the wear and tear.
There are always metal shavings left behind no matter how well you hose it, vacuum it or wipe it down. Those metal shaving are razor sharp so any time you inadvertently grind them into the finish while wiping down your mill you're scraping microscopic layers of paint off your work area. Particularly on the left hand side directly under the electrical conduit that slides back and forth as your mill-table moves around.
I've owned my mill just a little over a year and that electrical conduit has ground those razor sharp metal shavings so far down into the paint that in some areas it's down to the metal already.
Only recently did I take steps to eliminate having to stress over the premature wear of the painted areas that get showered with metal shavings.
Being an auto upholsterer by trade, I took some scrap vinyl and stitched it to form-fit inside the wells, on the table, the bellows and the door that covers the electrical.
On vertical surfaces this vinyl was held in place with magnets. On the rest of the horizontal surfaces it was just loose-laid flat.
When I saw how well it worked I went out and bought some "Pond-Liner" rubber sheet at the Home-Depot and replaced all the vinyl I'd originally stitched together. The rubber sheet can be taken out and hosed off outdoors which means minimal clean up on the surfaces of my mill where I once had a plethora of razor sharp metal shavings to deal with.
The remaining finish on my mill remains untouched except to wipe clean with a damp cloth; no more metal shavings to add to the wear and tear of my machine.
I have a piece of rubber sheet that's cut to fit the tubs on both sides, one for the table that hugs my vice so I don't have to scrape the channels in the table, One that hugs my 4th axis, the bellows and the electrical-panel-door. The vast majority of the shavings that are produced get washed down into my screen/filter. The shavings that hit the rubber mat stay there until I remove the mats and wash them down over a collection can out back.
About forty-bucks worth of "Pond-Liner" has cut my clean up time by more than half and my machine stays in good shape.
MetalShavings
