587,281 active members*
3,629 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC OM-C memory cleared, now can't input parameters, NOT READY alarm stays on
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    May 2013
    13
    Re: FANUC OM-C memory cleared, now can't input parameters, NOT READY alarm stays on
    The parameters contained in the diagnostic file sent by the manufacturer are as follows:
    N10300 P 00010100
    N10301 P 00000000
    N10302 P 01101011
    N10303 P 00101011
    N10304 P 00000011
    N10305 P 00010100
    N10306 P 00000000
    N10307 P 10000000
    N10308 P 00101011
    N10309 P 00000001
    N10310 P 00010100
    N10311 P 00000000
    N10312 P 10000001
    N10313 P 00001110
    N10314 P 00000000
    N10315 P 00000010
    N10316 P 00000000
    N10317 P 10000011
    N10318 P 01001111
    N10319 P 00000000
    N10320 P 00000010
    N10321 P 00000000
    N10322 P 00011100
    N10323 P 00101001
    N10324 P 00000000
    N10325 P 00000001
    N10326 P 00000000
    N10327 P 11010001
    N10328 P 01001101
    N10329 P 00000000
    N10330 P 00001000
    N10331 P 00000111
    N10332 P 11100010
    N10333 P 00011100
    N10334 P 00000000
    N10335 P 00010100
    N10336 P 00000000
    N10337 P 01101011
    N10338 P 00001110
    N10339 P 00000000
    N10340 P 00010100
    N10341 P 00000000
    N10342 P 00100110
    N10343 P 00111110
    N10344 P 00000000
    N10345 P 00101000
    N10346 P 00000000
    N10347 P 10110111
    N10348 P 00001010
    N10349 P 00000000
    N10350 P 00010100
    N10351 P 00000000
    N10352 P 00101111
    N10353 P 00101001
    N10354 P 00000000
    N10355 P 00000100
    N10356 P 00000000
    N10357 P 11000100
    N10358 P 00111110
    N10359 P 00000000
    N10360 P 00001010
    N10361 P 00000000
    N10362 P 00111110
    N10363 P 00111110
    N10364 P 00000000
    N10365 P 00000000
    N10366 P 00000000
    N10367 P 00000000
    N10368 P 00000000
    N10369 P 00000000
    N10370 P 00000000
    N10371 P 00000000
    N10372 P 00000000
    N10373 P 00000000
    N10374 P 00000000
    N10375 P 00000000
    N10376 P 00000000
    N10377 P 00000000
    N10378 P 00000000
    N10379 P 00000000
    N10380 P 00000000
    N10381 P 00000000
    N10382 P 00000000
    N10383 P 00000000
    N10384 P 00000000
    N10385 P 00000000
    N10386 P 00000000
    N10387 P 00000000
    N10388 P 00000000
    N10389 P 00000000
    N10390 P 00000000
    N10391 P 00000000
    N10392 P 00000000
    N10393 P 00000000
    N10394 P 00000000
    N10395 P 00010100
    N10396 P 00000000
    N10397 P 00010110
    N10398 P 00000000
    N10399 P 00000000
    N10400 P 00000001
    N10401 P 00000001
    N10402 P 00000010
    N10403 P 00000011
    N10404 P 00000100
    N10405 P 00000101
    N10406 P 00000110
    N10407 P 00000111
    N10408 P 00001000
    N10409 P 00001001
    N10410 P 00010000
    N10411 P 00010001
    N10412 P 00010010
    N10413 P 00010011
    N10414 P 00010100
    N10415 P 00010101
    N10416 P 00010110
    N10417 P 00000000
    N10418 P 00000000
    N10419 P 00000000
    N10420 P 00010110
    N10421 P 00000000
    N10422 P 00000000
    N10423 P 00000000
    N10424 P 00000000
    N10425 P 00000000
    N10426 P 00000000
    N10427 P 00000000
    N10428 P 00010110
    N10429 P 00000000
    N10430 P 00000001
    N10431 P 00000000
    N10432 P 00000000
    N10433 P 00000001
    N10434 P 00000000
    N10435 P 00000000
    N10436 P 00000000
    N10437 P 00000000
    N10438 P 00000000
    N10439 P 00000000
    N10440 P 00000000
    N10441 P 00000000
    N10442 P 00000000
    N10443 P 00000000
    N10444 P 00000000
    N10445 P 00000000
    N10446 P 00000000
    N10447 P 00000000
    N10448 P 00000000
    N10449 P 00000000
    N10450 P 00000000
    N10451 P 00000000
    N10452 P 00000000
    N10453 P 00000000
    N10454 P 00000000
    N10455 P 00000000
    N10456 P 00000000
    N10457 P 00000000
    N10458 P 00000000
    N10459 P 00000000
    N10460 P 00010100
    N10461 P 00000000
    N10462 P 11101110
    N10463 P 00101011
    N10464 P 00000001
    N10465 P 00000010
    N10466 P 00000000
    N10467 P 11110001
    N10468 P 00101011
    N10469 P 00000000
    N10470 P 10000100
    N10471 P 00000011
    N10472 P 01001000
    N10473 P 00000000
    N10474 P 00000000
    N10475 P 01110010
    N10476 P 00000000
    N10477 P 00000101
    N10478 P 00000000
    N10479 P 00000000
    N10480 P 00000001
    N10481 P 00000000
    N10482 P 00000000
    N10483 P 00000000
    N10484 P 00000000
    N10485 P 00000000
    N10486 P 00000000
    N10487 P 00000000
    N10488 P 00000000
    N10489 P 00000000
    N10490 P 00000001
    N10491 P 00000010
    N10492 P 00000000
    N10493 P 00100000
    N10494 P 00000000
    N10495 P 00000000
    N10496 P 00000000
    N10497 P 00000000
    N10498 P 00000000
    N10499 P 00000000
    And as it says in the parameter restoration touch, I first enter the parameters from 0 to 38 (The Fanuc coach we spoke to said from 0 to 38, not only parameter 38) , then the 900 and then the 552 (RS232 11- 9600 Baud rate).
    Then we turn off the control, turn on the control and send the parameters from the PC successfully, but the diagnostic parameters cannot be written manually or sent from the PC. The position of the key of the control panel, I have put it in both positions and nothing.
    Attachment 504622
    Attachment 504624
    Attachment 504626
Name:	Imagen de WhatsApp 2024-04-28 a las 17.32.47_c488fade.jpg
  2. #22
    May 2013
    13
    What is true is that in the manufacturer's parameters, the number 380 comes with a value, which blocks the writing of parameters if you put the value that comes from the factory.
    380 = 00010000
    I've changed it to 380=00000000 Because if not, it doesn't allow you to write anything in the parameters and sometimes I modify the 700 parameters for the travel limits if I machine parts that may collide with the machine's guards.
    Attachment 504630
    Apparently, this parameter to 0 disables the physical key of the machine's control panel by ignoring its position or leaving programs unprotected.
    It is true that in the procedure for sending the diagnostic parameters, it defines that the "EDIT" mode must be selected for the sending of the diagnostic parameters, but the only way in which the reception can be activated is with ESTOP pressed, which would be in MDI mode
  3. #23
    Dec 2009
    968
    check in diagnose the G122.3 if it is really 0
  4. #24
    May 2013
    13
    Quote Originally Posted by zavateandu View Post
    Ok tomorrow I'll look at it. The problem is that it can't be modified. When you talk about 122.3 to 0 would it be 122=00001000 for example? Does that 1 have to be 0?
  5. #25
    May 2013
    13
  6. #26
    May 2013
    13
    That photo of parameter 122 is after a "RESET" + "DELT" + POWER ON. Even then, it doesn't let you manually edit the Diagnostics parameters. Tomorrow I'll re-enter the 900 and send the general parameters and check the 122 parameter.
  7. #27
    May 2013
    13
    Hello.
    I found this thread in another forum where it talks about a "lock key" in "operator panel" but I don't quite understand where it can be.
    "reloading Hardinge vmc1000II/Fanuc omd pmc data" Search for the name of the thread if you are interested. I can't put the name here because of the rules...
    Attachment 504646
    Attachment 504648
    I have tried with all the options in "ON" and with all in "OFF" and nothing.I have asked the manufacturer again, who has not yet told me anything about the blocking of the diagnostic parameters 300-499
  8. #28
    May 2013
    13
    In the end, we couldn't enter the parameters because it's impossible to write them. The manufacturer has sent instructions to enter the parameters as we are doing and you can't. The G122.3 parameter is set to 0 and does not change when the key is moved, but in the electrical diagram of the machine it says that the key is seen on the x8.6 and the technicians of Fanuc Spain say that if the G122.3 is not set to 1, it does not allow the diagnostic parameters to be written. The 905 parameter that defines the type of PLC it has, cannot be changed to any type (I think it would be G122 00000001 type L) but it does not allow you to put any value. My question is: if I change the control to a used one, would the machine work with the manufacturer's parameters? I saw on a forum that he changed the two EPRONs to ones supplied by the manufacturer and the machine worked. What would I need to change in order to run the machine? I'm desperate. I need help
  9. #29
    May 2013
    13
    Hello again. I have very good news. The machine is already working. That gives a small problem, which is that in MDI mode you can't run anything, but I hope to be able to solve it soon.
  10. #30
    May 2013
    13
    To sum up, the problem is that the 900 parameters that I have on a sheet of paper, only reach 929 (defined by the manufacturer) and talking on the phone and through emails, I had already been testing for four days with a technician from Fanuc Spain. Yesterday I wrote to you proposing several options and they were all to act on the memories of the memory board of the control. Then he replied with a parameter file from another machine to do a final test and that was the solution!. In that file were included the parameters 900 (in which the manufacturer of our machine sent me, it does not include them) and I will tell you in more detail the complete procedure, but now summing up, in the parameter 932 is the problem. Actually, right now I'm using the parameters 932, 933 and 934 from the file sent to me by the Fanuc technician, but doing tests, I determined that the problem is in 932.5, that if it's not at 1, the PMC doesn't start, And if you don't start the PMC, you can't write parameters 300 to 499 to it.
    When entering the 900 parameters of the manufacturer of my machine, I added the parameters 932, 933 and 934 of the copy that had been sent by the Fanuc technician and when restarting the numerical control, the parameter 905 had been automatically changed to N905 00100000 and after sending the NC parameters by RS232, restart the control again and the PMC appeared and sending the day parameters again by RS 232, they are written without problems.
    I'll go through more detailed information later. Now I don't have all the data from my phone. I would like to take this opportunity to thank you for your help, although in this case, I almost gave up. It has been three weeks of testing and in the end it has been resolved. Only a few parameters were missing.
    After contacting the manufacturer several times via email, they didn't give me any solution. I don't know if even the manufacturer knew the problem was there. The parameters 932 933 934 I don't know what they refer to and I asked the Fanuc technician and he told me that they are options and that they are confidential. I'm going to contact the manufacturer to see if they can tell me exactly what parameters I should put on the 932, 933 and 934 so that nothing on the machine is damaged.
    Best regards
Page 2 of 2 12
  1. Acramatic 850SX: memory board MMC was cleared
    By guhl in forum Cincinnati CNC
    Last Post: 10-25-2012, 08:09 PM
  2. Sodick A530D EX21 E203 Memory cleared?
    By edmengineer in forum EDM Discussion General Topics
    Last Post: 07-08-2010, 09:34 AM
  3. fanuc parameters cleared
    By Mikey69 in forum Fanuc
    Last Post: 05-12-2009, 05:44 AM
  4. Fanuc 6m stays in "not ready" mode
    By hopcycle in forum Fanuc
    Last Post: 01-30-2009, 02:58 PM
  5. Machine stays in NOT READY at power on!?
    By MITYDR in forum Fanuc
    Last Post: 09-05-2006, 03:39 PM
