587,189 active members*
2,390 visitors online*
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Sep 2005
    1740
    Re: Saturn 2x4 NEMA 23 Plug and Play
    Quote Originally Posted by wmgeorge View Post
    Nate I sent a email but my 4x4 34 Plug in Play has 4 prox switches, which of the 6 or so connections on the box do I use? I have 2 mounted on the X and 1 on the Y , 1 on the Z. Do you have a special setup file for Mach3 other than the one on CNCRouter parts website? You have my email, thanks.
    Got it, thanks.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  2. #22
    Sep 2005
    1740
    I got mine up and running plus cut a file. How are you doing with this one?
  3. #23
    Still haven't gotten the other half of the Z axis coupler. Looks like Nate sent it out this morning. In the process of moving, so I'm hoping to be cutting files by next week. I just wish everything shipped the first time...
  4. #24
    Well, finally done. Mostly.
    Moving was a pain, but it all went well. Managed not to damage anything. Got the coupler the day of moving, so that was fun.
    Went to the store and picked up parts to build a proper electrical setup. Ran 220v to the garage in the new house, and just need one more face plate to be up to code. As far as the machine, it works beautifully. For some reason the profile Nate sent me had an incorrect setting for the Z axis steps/in, which I was able to correct by digging through difalkner's thread. Spindle was already trammed nearly to perfection, I was impressed. I ran a simple drilling toolpath to start, and a second to countersink each hole. I only ended up putting 3 screws per rail.
    Afterwards, I ran a pocket toolpath and machined the working area flat. Thankfully I've been using Aspire and Mach3 for a couple years now, so not too much difficulty in doing this. And I finally cut my first v-bit engraving on this machine, on a piece of scrap mdf per request of my sister.
    Gonna try a v-carve inlay tomorrow, I believe that to be a true test for a machine. So far so good, hopefully I'll put a lot of material through it before leaving for my mission!
  5. #25
    Well, the machine is working to my satisfaction. Despite having no homing/limit sensors, or a z touch off plate, I carved two inlays today. I felt proud
    Thanks Nate for all the help. We'll be using this for years to come...
  6. #26
    Sep 2005
    1740
    Very nice work.
  7. #27
    Nov 2014
    724
    Quote Originally Posted by BasementEngineer View Post
    Looks great! Are you using a Vectric product, Fusion 360, … ?
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
  8. #28
    I'm using an older copy of Aspire. Used to have Solidworks, but no longer, so need to learn Fusion for 3d work.
Page 2 of 2 12
  1. Replies: 13
    Last Post: 06-30-2018, 02:23 PM
  2. Need Wiring Diagram For Nema 34 Plug & Play.
    By NotEZ2Beat in forum Avid CNC
    Last Post: 03-23-2018, 02:40 AM
  3. Replies: 4
    Last Post: 01-08-2018, 11:36 PM
  4. Upgrade from NEMA23 Plug and Play to NEMA 34?
    By ColletandBit in forum Avid CNC
    Last Post: 05-23-2017, 07:05 AM
  5. 4-Axis NEMA 34 Plug And Play System
    By pissedatnate in forum FineLine Automation
    Last Post: 09-25-2016, 12:26 AM
