Originally Posted by
SCzEngrgGroup
Where your drawing has an arm with a radiused end acting as a cam, replace the radiused end with a ball bearing, so the contact with the other arm is the outer race of the bearing, and you rolling, rather than sliding, contact. If you slot the end of the arm so the bearing fits into the slot, then drill a cross-hole and put a bolt through the cross hole, and the ID of the bearing, to hold the bearing in place. This will GREATLY reduce friction and wear. You'll still have very high pressures at the contact point, so you'll likely need to put a hardened surface there.
You'll have to provide a radial support for the air cylinder shaft, as they are not designed to take high radial loads (which will also destroy the shaft seals). A bronze bushing is probably your best bet there. You can also allow the cylinder to pivot, so the force always stays aligned to the cylinder axis.
Ray L.
