587,535 active members*
3,676 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Dinosaur skeleton, and other models, DXF files.
Page 161 of 224 61111151159160161162163171211
Results 3,201 to 3,220 of 4471
  1. #3201
    May 2009
    Hi can any body tell about technique he did for z axis?
    hear is video link
    [ame=http://www.youtube.com/watch?v=tTyGa0pPIl0&list=UUPBrAtsL72ni0R5uu-0y__g]GALEKS G10 image cnc engraving machine - YouTube[/ame]
  2. #3202
    Let's all calm down a bit and resume sharing some dxf files (group)
    A styrofoam or EPP cactus with chocolate bar thorns:
    And a cutting board:
    The files: dxf.zip
    Christian
    My CAM Software and CNC Controller: www.estlcam.com
  3. #3203
    Aug 2010
    113
    Paper skins
    Quote Originally Posted by Cutter99 View Post
    When I was a kid making balsa wood model airplanes we would cover the skeletons with a thin paper skin and paint that skin after some sort of hardening coat.
    Have you ever tried that with your dino models Mr. Makecnc?
    thats a great idea ! ...i am going to do some research on how they do that and give it try. i think it would look great on a model Rocket if you could get it to look translucent and then put some sort of LED inside to make it glow
  4. #3204
    Dec 2010
    92
    Markus, I will have a look ans see if I have a picture, if I don't it will be somewhere in the 267 pages and 3200 odd posts.
    Regards
    Eric
  5. #3205
    Dec 2010
    92
    Markus, I found them!
    Eric
  6. #3206
    Apr 2011
    Thank you very much.
    I'm looking at the possibility of making a dollhouse for my little girl.
    If you have any plane I'd appreciate it.
    Quote Originally Posted by eric5501 View Post
    Eric
  7. #3207
    Aug 2010
    113
    [QUOTE=turkazer;1223167]Hi can any body tell about technique he did for z axis?
    thats awasome ! i would like to know that myself it looks like an angled spindle that is attached to a stepper or servo that rotates the whole spindle very slightly to give the Z movment for the engraving bit which looks like it also is a specialized bit..but i may be wrong
    and i think you would need special software as well
    i am curoius now so will write the company and see if they are willing to shed some light and report back
  8. #3208
    Nov 2011
    211
    There looks to be no Z axis movement as we know it (straight up and down) so they tilt the Z instead giving them a z axis of sorts. At least thats the way I see it
  9. #3209
    I think the pivoted spindle has 2 advantages:
    - the grinder bit touches the workpiece only with its fast outer circumference and not with the basically just scraping center. This is much more effective and also reduces wear significantly...
    - I'm also pretty sure that the whole thing is spring loaded -> makes sure that the grinder bit gets reliable contact to the workpiece but only with little and constant force.
    The latter would also be able with a normal Z-Axis - but more complicated.
    Christian
  10. #3210
    Aug 2010
    113
    Quote Originally Posted by Christian Knüll View Post
    Christian
    i am thinking that there is some belt driven mechanisim behind the spindle that acts to turn..or to give a sort of Z axis wobble if that make sense.?.to engrave the picture the bit must have some sort of computer controlled up and down movement to make the 3d dimension that creates the image so just pivoting the spindle with a spring load on it would perhaps not achieve this.. this is why i thought maybe the whole spindle sort of wobbles in Z by means of a belt driven by a stepper or servo to get that movement it would only work for tiny Z movements though so very shallow engraving like this but would not work for deep engraving due to distortion of the image...i could be totally wrong here but thats what my brain is telling me . if thats not how they are doing it ..its a cool idea anyway and i might try making one to see what it can do...not having to wait for Z screws to turn could speed up an engraving process by a ton yes ? hmmmn interesting stuff..opens a whole new dimesnion of thought here
  11. #3211
    Dec 2008
    15
    Quote Originally Posted by makecnc View Post
    If it works I want some sort of reward...
  12. #3212
    Aug 2010
    113
    wood boats
    i wonder if i cut a very light hull stucture for a steampunk style boat from say basswood
    and used that method to skin it i could put a rubberband powered prop in it
    and make some sails and wings and other gizmos on it
    how cool would that be
    i am going to give it a try
    what type of reward did you have in mind
  13. #3213
    Dec 2008
    15
    Your project CDs...? (please?)
    I think you will take it to the next level just skinning everything and then painting. It is like old school model building.
  14. #3214
    Mar 2006
    115
    Lauan plywood face veneer
    Hello all,
    I have been using 4.75mm lauan plywood to cut wooden puzzles from. But sometimes, it will peel a little veneer from the face when I cut. I have been using an upcut bit and I guess that is what is causing it, but it only happens occasionally. Is there a way to prep the stock to help reduce it from happening? Or do I just need to move to a downcut bit?
    When I get a peel, it is more like an area that didn't adhere well. Would an iron on a cotton steam setting heat it enough to make the glue underneath heat up to stick it, or is it just a waste of time? It drives me nuts to have to lay out just two or three pieces to recut to replace those that pealed in a 45 piece puzzle.
    Joe
  15. #3215
    Nov 2012
    Quote Originally Posted by simo212 View Post
    Hello friends, I'm looking for design "Pen-Holder"
    Please plan dxf, pdf or jpg.
    Thanks for the help.
    Simo.
    Hi!
    I have this bycicle pen holder.
    Attached Files Attached Files
  16. #3216
    Sep 2012
    Thread rewamp
    Fabrythrash now is here ..
    a brand new pretty good cnczone fellow !
    I'm ten thousend miles from quite all of yours ... I'm pretty sure ...
    I've readed all the post from the beginning of this thread... I've understood quite all the discussions here you guys.. even if I'm not part of Yours ..
    but somethin don't seems go well ..
    It tooks me about 2 weeks .. :-) more than 250 posts and so on ..with all the discussions .. :-)
    Seems someone pretty good it's not happy here .. more than one
    Anyway .. due to the fact that I've downloaded too much .. posteds anything ... but learned really a lot ..
    I'll need to start with a re-post just because I need to understand if I'm in the right direction ... with softwares and dimensions
    So I'll start with a re-post D-Torxo-Cat completely revisited.
  17. #3217
    Mar 2006
    118
    Welcome To the forum Fabrythrash. Yeah there have been some good times and some bad times here. HOpefully that is over. This is a great place to learn and some great guys to give help and to answer all you questions (should you have any).
    Chuck
  18. #3218
    Mar 2007
    463
    Fabrythrash
    In the text on your picture it says you said that you have the DFX of these pics. If so would you post them also as it is very hard to make one from your picture. Or if you could post a nice clear 2 or 3 meg picture, that would be good.
    Larry
  19. #3219
    Sep 2011
    10
    I am looking for a cow 3d puzzle
    If someone has it let me know thank you
  20. #3220
    Aug 2010
    113
    Quote Originally Posted by vince_team View Post
    try here for a free one
    CNC Mentor.com: | Blog | Docs | New Doc
    or here for a bought one with a nice assembly guide DXF Projects & Patterns for CNC lasers Routers Scrollsaws
  1. Dinosaur Puzzle
    By Rosey Musick in forum Machine Created Art
    Last Post: 04-11-2013, 07:03 PM
  2. Dinosaur Trade
    By roninB4 in forum Diemaking / Diecutting
    Last Post: 11-18-2012, 03:01 PM
  3. Who will stop this china Dinosaur??
    By smtclman in forum News Announcements
    Last Post: 12-19-2010, 11:05 PM
  4. Epoxy Granite "s Skeleton
    By hkxy in forum Epoxy Granite
    Last Post: 05-03-2010, 02:35 AM
  5. Replies: 2
    Last Post: 03-09-2007, 08:47 PM
