Chris be careful.
Sorry I have not posted in a long time and may not be up to date.Basically glass fiber carbon fiber and the like as cloth or rovings under vacuum infusion plus injection is cool as the fiber/resin ratio is about 50/50 by weight.Trying to get 90/10 epoxy aggregate is not possible with a small % age of glass fiber no matter how much vacuum or injection pressure you have.The space between the aggregates is minimal and the glass fiber will complicate the procedure.The fibers will "wash" at the injection point plugging the resin path and building high pressure in the mold.If you are infusing with a high pressure pump,good luck.The mold must be very strong to resist the pressure buildup.Forget the glass fiber for now.
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
