587,672 active members*
3,213 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Will build a Benchtop mill including Castings! Comments appreciated.
Page 15 of 15 5131415
Results 281 to 300 of 300
  1. #281
    Nov 2005
    334
    Re: Will build a Benchtop mill including Castings! Comments appreciated.
    The Basic's of Machine #1 have been completed for some time and Greg & I have been
    considering what's next !
    We have installed a Gecko 540 in our Machine Console which can drive 4 axis motors,
    and we are presently utilizing only three!
    The subject of installing a TRUNION has been considered.
    W. Smith, Mission Viejo,CA
  2. #282
    Dec 2004
    1865
    Nice Trunnion!
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  3. #283
    Nov 2005
    334
    Mike, Your comment is much appreciated!
    The Trunion Table picture enclosed in my last post was one of several
    included in my post #238, page 20 of this Thread.
    We have now decided to prototype the concept and have received the casting
    for the rotary table. ( see enclosure)
    Have observed quite a few Amateur Builders experimenting with 4tn & 5th axis
    these days and this seems like an easy way to get there!
    W. Smith, Mission Viejo CA.
  4. #284
    Nov 2005
    334
    I have spent considerable time recently researching Arduino/Grbl and stumbled upon an interesting thread here on CNC Zone.
    The author is GRBL GRU and is developing a terrific FREE Cad program on his thread in real time!
    forums/uncategorized-cam-discussion/311876-cnc-forum.html
    Definitely worth a look!!
    W. Smith, Mission Viejo, CA
  5. #285
    Nov 2005
    334
    I haven't posted recently because I had submitted the information on
    our "ULTRA" Model Bridge Mill to Digital Machinist Magazine
    and was waiting for the article to be published.
    Our new mill was featured on the cover of the Fall quarterly issue
    published on Oct 6, and the editor George Bulliss and his staff did
    a magnificent job in composing the article, " Design and Construction
    of a CNC Bridge Mill".
    They even referenced this thread for background information on
    the project!
    If you are a subscriber, please let me know what you think of the article.
    Your input would be much appreciated!
    W. (Ted) Smith, Mission Viejo, CA
  6. #286
    Nov 2005
    334
    This is the front page of the latest issue of Digital Machinist Fall 2017 vol 12
    Attachment 376054
  7. #287
    Feb 2007
    4553
    Totally Awesome!
    Well Done!
    Congratulation's
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  8. #288
    Jan 2009
    17
    Insufficient superlative vocabulary to commend the Smith family engineering co!
    Great work gentlemen.
    I found your work today in digital machinist magazine, then read this thread end to end.
    That took a while.
    It was Well Worth It!
    Bravo!
    Please count me in as interested in bridge mill castings and drawings set if they ever become available!
    Cheers!
    Chris
  9. #289
    1187
    Yes Smith, great work as always and again glad to see your kicking !!!!
  10. #290
    Nov 2005
    334
    Hi Guy's,
    Hope more than 3 of you were able to view our article in Digital Machinist Magazine!
    IT was much more concise and to the point than what I presented here!
    W. (Ted) Smith
  11. #291
    Nov 2005
    334
    Hi All,
    Greg & I have begun modifications on our current design of the Bridge Mill.
    The latest configuration will expand on our spread upright design which was
    shown earlier. Enclosed are some sketches of the proposed design.
    Proposed Changes:
    1.-Add 2-3 inches to the height of the Bridge Columns to raise the existing Cross Bar.
    2.-Add two extensions to the existing Base Plate to add a footing for the extended columns.
    I've removed the patterns from the shed and have started work on the modifications.
    Hope to show some Progress soon!
    W. (Ted) Smith
    Attachment 380548Attachment 380550Attachment 380552
  12. #292
    Sep 2016
    7
    I like it. rngr1
  13. #293
    Nov 2005
    334
    The New Configuration Bridge Mill is finally in work!
    The revision to the Pattern for the Side plate is in work and 3.5 inches was added to the height.
    This translates into an additional 3.5 inches in Z axis travel or 11.0 in. total.
    We anticipate adding the wings to the Base plate will be a little more time consuming but
    this modification will allow increasing the machine table from 11.5 x 12.0 to 12.0 x 16.0 in.
    It is our intention to increase the work area by passing long pieces both front to back as well as side to side.
    more progress next time!!
    W. (Ted) Smith
  14. #294
    Nov 2005
    334
    The next task in the Bridge Mill upgrade is to add "wings" to the Base Casting.
    This revision should not be too complicated because there is adequate space available
    to add the two extensions ( wings).
    http://www.cnczone.com/forums/
  15. #295
    Nov 2005
    334
    Before Modifying the Base Plate Pattern to incorporate the wings
    I decided to test the concept by adding the wings to an existing Base
    Plate casting !
    Looks like some additional machining will be required on the prototype
    but think to results should be interesting!!
  16. #296
    Nov 2005
    334
    Quote Originally Posted by CNCfun&games View Post
    Plate casting !
    The Match Plate Patterns have been Modified to Incorporate the changes and I have decided
    to drop the patterns of at the local Aluminum foundry and have several sets if the parts cast.
    With all the emphasis on 3D Printing these days, I believe this configuration would provide
    the basis for a very nice 3D printer.
    At any rate it sounds like a fun Project!!
    W. Ted Smith, Mission Viejo, CA
  17. #297
    I recently picked up a copy of digital machinist shown above and stumbled onto this build. Wow this is amazing. Were plans ever published that others could follow? Been catching up on the thread here so if it is in there I apologize for not seeing it yet. Congrats on making the magazine and all the dedication, currently reading about 2012-13 changes. Thanks again.
    Edit: Interested in a cad model, step format is fine. Again thank you.
  18. #298
    Oct 2013
    543
    It's been 3 years and not a peep from the OP. Guess that's how things go in 'Hobby Town'...too bad, it looked like a viable little machine.
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  19. #299
    Yeah that is ashame. Thanks for letting me know.
  20. #300
    The unfortunate reality is that I think most of this forums members have slowly moved on to other forms of internet communication. Likely Facebook. The problem is that groups there are so disorganized because anybody can create one on a whim. I think dedicated forums will make a return at some point, but the love for Facebook is going to have to dwindle a bit.
  1. Convert a 2 axis Cross Slide to CNC-comments appreciated!
    By CNCfun&games in forum Benchtop Machines
    Last Post: 10-25-2017, 06:21 PM
  2. Will Build a Moving Gantry ROUTER-comments appreciated.
    By CNCfun&games in forum CNC Wood Router Project Log
    Last Post: 12-25-2016, 01:06 AM
  3. DIY benchtop mill build
    By mkuivamaki in forum Benchtop Machines
    Last Post: 03-19-2014, 08:54 AM
  4. Designed from the ground up - including castings
    By Hack in forum Vertical Mill, Lathe Project Log
    Last Post: 02-09-2012, 11:09 PM
