587,138 active members*
3,827 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Fit for leader pins
Results 1 to 2 of 2
    Jun 2008
    262
    Fit for leader pins
    I just finished a mold. I had a problem with the bushings and leader pins. I made it a press fit .001 inch on pins and bushings - 3/4 pins with OD of about 1.125 on each.
    Didn't work too well. The bushings got pretty tight. I eventually made it work.
    Does anybody know of mold component charts as far as the fit is concerned?
    I've been looking but nothing so far.
    i build the braces that keep american teeth straight......tick tick tick
    Feb 2007
    498
    you dont need to press fit them that tight,i usaully bore the hole than ream them with standard reamer,the pins and bushing come over size to press in already,so by going an extra .001 you were too tight,the bushings only have .0015-.002 clearance so yours closed up and im guessing didnt go together
  1. PBC Linear Named Leader in Engineering by Design World
    By Pacific Bearing in forum News Announcements
    Last Post: 12-22-2009, 10:04 PM
  2. Replies: 2
    Last Post: 01-30-2009, 06:35 PM
  3. Fanuc 15M (Leader Diagram)
    By Afzal in forum Controller & Computer Solutions
    Last Post: 09-23-2008, 08:31 PM
  4. Nominations for leader of the CAD plans
    By teilhardo in forum DIY CNC Router Table Machines
    Last Post: 09-11-2005, 06:47 PM
