OK,
So my reseller finally sent me a post processor that was "close enough". After some editing it seems to be working. Now the largest problem is my understanding of the code I'm putting out.
Anyway, I've run into another problem with CAMWorks that I simply cannot solve. I have a 1.25" x 1.25" x 7.5" piece of aluminum stock which has numerous features machined into it. Everything works fine except the filleted corner which runs the full length of the part. The fillet has a 0.250 radius and runs the length of one of the 7.5" sides of the part as well as down the 1.25" sides of the part, on the same side. CAMWorks seems to think that machining the fillet from the side (with the part extending vertically out of the vise) is the best way to do it even though I have a corner-round machine tool defined in my tool crib and all of the AFR features turned on. I can force it to profile machine the fillet with an end mill from the top but that takes way too much time and produces a poor finish. Can anyone guide me on how to get CAMWorks to use the corner-round tool to do one sweep and produce the fillet I need? Thank you if you can!
