Hi again
why when a toolpath is computed it doesn't touch the plane that it will be working on? It's offset around an 1/8" or so above the part
Notice the planar surface is sitting on the part that will be milled
The lower bead z level finish sits high and also the toolpath that is between the lines is set high above the 2 lines that were selected
Is this normal? I check for settings, material left is set a 0
Thanks for any info on this
Gary
