That would be an sensor for reference of spindle?
Where this sensor should be, inside of the motor?
Manual adjustment (moving) or with parameters?
There is no spindle load meter on operator panel.
Maybe this could be seen in some parameter/diagnostic? 0M, I doubt.
Tried, again same thing.
I tried lower and higher RPM,and also changed feed.
Buzzing is all the time the same.
