587,475 active members*
3,294 visitors online*
Results 1 to 5 of 5
    Apr 2010
    motor direction in Mach 3
    I am using a rack-n-pinion drive system for the Y axis. I have two separate motors for this on on the left side and one on the right side. since the motors are mounted facing the opposite direction I need the motors to turn in opposite directions. I have been told to use two different axis controllers for this One the Y axis controller and the A axis controller. How do I get the two different motor controllers to spin the motors in the opposite direction. These motors need to do the exact same thing but spin in the opposite directions. does anyone kn ow how to do this in Mach 3. It has also been suggested that I reverse polarity in one of the motors, this is simple to do but how do I get the Y axis controller and the A axis controller to do the same motion at the same time.
    Jan 2006
    357
    Go to config then down to slave axis
    35538
    You can reverse a motor in Config >Homing/Limits. Check the "Reverse" column. You can also reverse it by toggling the active low settings for the dir pin.
    And as Gary said, you Slave them. Make sure all settings are exactly the same for both motors in motor tuning.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2010
    Thank you Jerry and Gary. I will do this and post to let you know the results. It is sure nice to have this form available. There are going to be many question, this is all new to me.
    Apr 2019
    10
    Re: motor direction in Mach 3
    Very much a necro post but fut to save anyone else the 2 seconds , this is the answer " You can also reverse it by toggling the active low settings for the dir pin." I tested this " You can reverse a motor in Config >Homing/Limits. Check the "Reverse" column." but I believe that's just the homing direction rather than the stepper motor direction.
  1. Motor moves one direction using mach 3
    By icncsigns in forum DIY CNC Router Table Machines
    Last Post: 12-29-2013, 03:01 PM
  2. Mach 3 running the wrong direction
    By teamtexas in forum Mach Mill
    Last Post: 11-13-2013, 01:58 AM
  3. mach 3 slave motor(stepper) turns only one direction??
    By xkadet in forum Machines running Mach Software
    Last Post: 01-03-2013, 09:59 PM
  4. advice on direction control for backgear to mach
    By jking in forum Bridgeport / Hardinge Mills
    Last Post: 10-22-2009, 11:20 PM
  5. Replies: 0
    Last Post: 10-10-2009, 11:28 PM
