Thought I had this fixed. I'm modifying the Generic Fanuc 5X Mill post, ( using X4, MU3) for our HAAS VF-4, with a Tsudakoma\ TN-160 mounted on it. B tilt's in -X(0-90) & A rotates (360). Tweeking for a couple of day's & can't get it correct. I'm uploading a pic of how the 5th axis is on the mill. I know this much is correct, because I've set it up in UG NX5.(lot's easier). Also uploaded a text file with the code I'm getting, & the part of the post I'm tweeking. Y will stay at 0, & X will stay at X-7.5886. Should be only one "B" index, (55deg), & 6 "A" output's, starting with, 0,60,120,180,240, & 300 with the test part I'm using. Steve, if your out there, I need your help on this one, You have helped me in the past with post issues , before. Thank's in advance.
Regard's,
Harold
