587,613 active members*
3,307 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper driver problem (leadshine m742)
Results 1 to 2 of 2
    Mar 2011
    hello ppl!
    im new here.. sorry if this is becoming a double post but i tried to search my prob and nothing came up..
    i have leadshine M742 stepper drivers and mecheltron 60bygh450-02 3Nm stepper motors. the motors are 8 wires. when i connect the motors to the driver, i get problem with the A coil input. when the A coil input is left unused, the stepper driver stays in normal mode(with power supply connected) but if i connect the A coil also, to the driver, i hear the motor jump and the stepper drivers goes into fault mode, showing a red LED as opposed to a green one when everything is fine. i checked with another motor, using different windings of the motor, used a different driver too, its the same problem.. the driver jumps into a fault mode..
    i cant figure what the problem could be..
    DIP switches on off in a speical way.. ?? anything??
    thanks for any help.
    May 2005
    1397
    Umm... probably a dumb question but you aren't actually connecting and disconnecting motor coil wires while the power is on are you?
  1. Problem with Probotix stepper motor driver?
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 03-16-2011, 09:15 PM
  2. Leadshine MD882 Driver E-Stop
    By electrosteam in forum CNC Machine Related Electronics
    Last Post: 11-09-2010, 03:51 AM
  3. 3 phase stepper driver problem
    By vsystems in forum CNC Machine Related Electronics
    Last Post: 01-14-2010, 04:38 AM
  4. Leadshine DM556 stepper motor driver.
    By Kingjamez in forum Stepper Motors / Drives
    Last Post: 08-02-2009, 03:22 PM
