587,201 active members*
2,873 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Gcode reader displays toolpath
Results 1 to 4 of 4
    Jun 2006
    340
    Can anyone recommend a software program that reads a Gcode program and then displays the tool path in 3D?
    There are a few Gcode editors with TP display on the internet but some are dated and others don't to have much toolpath display capability.
    It would be great if SprutCAM could do it and match it to the workpiece or part.
    Yes I know Mach3 will do it but I find the display provides little useful information.
    Bevin
    Jul 2004
    81
    I've been using NCPlot for the past couple of years. In addition to viewing toolpaths, I find the transformations useful for last minute changes at the mill. For example I can change the zero location, rotate, mirror and scale the gcode.
    The tool list feature is nice to make sure Sprutcam hasn't scrambled all the tool numbers in my library. Again.
    Apr 2006
    439
    I am also a big NCPlot fan. !!
    It is what I use to write all my code. And how I learned. Can't say enough good things about it
    Scott
    www.sdmfabricating.com
    Jun 2006
    340
    Thanks.
    The specs look very impressive. It is a little more expensive ($299) than I was hoping the price would be, but it seems very capabie.
    I will give it a try in the next few weeks, and let you know how I find it.
    Bevin
  1. 3d dxf toolpath to gcode converter
    By JBV in forum G-Code Programing
    Last Post: 04-16-2009, 10:30 PM
  2. HMI serial protocol Beijer displays
    By Lbase in forum CNC Machine Related Electronics
    Last Post: 08-15-2008, 05:42 PM
  3. Replies: 11
    Last Post: 08-15-2007, 09:06 PM
  4. Solidworks 2006 with two displays ?
    By karlis_m in forum Solidworks
    Last Post: 11-10-2006, 05:39 AM
