587,098 active members*
5,610 visitors online*
Thread: 5 axis setup
Results 1 to 2 of 2
    Dec 2010
    25
    5 axis setup
    I'm thinking of setting up a small mill like sherline or tiag with a trunnion table for 5 axis. (this is my understanding and was looking for clarifiction) Mach 3 to a smoothstepper handles 5 axis through dual parallel ports. Can I then hook one to a g540 and the othe port to a BOB to a g250 to get a 5 axis setup?
    ps. can't believe no one here has a comment. Or on the geckdrive site forum. I didn't think it was that tough of a question for you gurus out here. Post on the DIY forum and nada. I guess the Gecko people don't even look at their own forum questions. Is that my question is so far off no one wants to wade in?
    Apr 2004
    5739
    Even though I don't know the answer
    I'll reply anyway, just so you don't feel neglected...
    It seems that the main advantage of the G540 is that it handles 4 axes without requiring a breakout board. If you need to get one anyway, you might as well use individual geckodrives. The advantage would be that you could go with a bigger power supply (80v vs 50v) and potentially get better performance from your motors.
    You might ask Komar how he set up his system, which seems a lot like the one you're looking to build. Here's a link to his post:
    http://www.cnczone.com/forums/taig_m...ig_5_axis.html
    Let us know what you end up doing, okay?
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
  1. Mach3 A axis (4th axis) setup?
    By cadcamslawek in forum Mach Software (ArtSoft software)
    Last Post: 01-18-2012, 03:23 AM
  2. 4 axis setup
    By woodman08 in forum Mach Mill
    Last Post: 11-14-2009, 12:22 AM
  3. 4th Axis Setup Help
    By Cartierusm in forum MetalWork Discussion
    Last Post: 03-19-2009, 04:19 AM
  4. My Axis Setup is Not Right
    By Mr.Chips in forum Machines running Mach Software
    Last Post: 01-13-2009, 02:24 AM
  5. Z Axis Setup
    By musicmkr in forum DIY CNC Router Table Machines
    Last Post: 06-10-2004, 05:33 AM
