I've just received a Deepgroove Taig CNC mill and was wondering if I will need a postprocessor file. I'm using Camworks and Mach3. I'm new to CNC so I hope someone can help.
Thanks,
Joe
Thanks,
Joe
Hi, I'm also interested in finding a postprocessor CAMWorks to Mach3. I've read that is possible create a post-processor using the program UPG,but I do not know, please help. A greeting and thanks
from camworks , select Fanuc postprocessor , works fine here with mach3
I can not run the follow g code in Mach3. What changes I have to do?
O0001
(Main Spindle)
(Must Customize Main Spindle Per Machine)
N1 G50 S3000
N2 T0100 M42
N3 G00 G97 S1001 M03
N4 G00 Z2.743 T0101 M08
N5 X75.962
N6 G71 P7 Q9 U.254 W.254 D2540 F.007
N7 X60.096
N8 G01 Z-.193 F.007
N9 G02 X70.089 Z-16.926 R35.471
N10 G97 S3281 M09
N11 G40 G00 X508. T0100
N12 G00 Z254.
(Main Spindle)
N13 M01
N14 G50 S3000
N15 T0200 M42
N16 G00 G97 S899 M03
N17 G00 X65.176 T0202 M08
N18 Z2.347
N19 X60.096 Z-.193
N20 G02 X70.089 Z-16.926 R35.471
N21 G00 Z-19.866
N22 G02 X60.096 Z-36.6 R35.471
N23 G00 X508.
N24 G97 S3281 M09
N25 Z254. T0200
N26 M30
I know that the problem is Line 6. G code was generated in CamWorks.
Regards
M Zambrano
hello,
like you i'm looking and not finding .. did you ever find an answer???????
i'm using a camworks OEM software package, and running it through a 3rd party mach3 package to a home built cnc machine. would really like to find a postprocessor
larry from alaska
Hi Larry
I did not find. I started working with BobCAD lathe version. This software has a processor for Mach3 and now everything is fine.
Mike
