587,541 active members*
7,382 visitors online*
Page 9 of 10 78910
Results 161 to 180 of 191
  1. #161
    Feb 2010
    3447
    Quote Originally Posted by 15mgtar View Post
    Mark and Bartus why don't you guys use servo motor instead of stepper? are they better for the job? but servo is more precision.
    Probably cost. I can only imagine how much money those monster steppers were, let alone servos!
  2. #162
    Feb 2010
    202
    one stepper motor 50Nm - ~800$
  3. #163
    Jan 2009
    396
    how much is it to replace it with servo motor (what is the spec for servo)? and what gearing do you use on the rack n pinion? I'm really interested on building one someday
  4. #164
    Feb 2010
    202
  5. #165
    Jan 2009
    396
    very nice machines Bartuss1! I love the 5 axis one. btw how do you level and line up all those linear guides and ballscrews???
  6. #166
    Feb 2010
    202
    very easy
    shows the example of the latest machines
    http://picasaweb.google.pl/soltys.de...zarkaKopiarka#
  7. #167
    Jan 2009
    396
    now what if the the table isn't perfectly square and level??? how do you build your table that is totally flat and square? because for all I know that none square pipes are totally straight and event they have little difference in thickness and dimension.
  8. #168
    Feb 2010
    202
    Smile
    it was welded on the grinding table, and it is the horizontal surface
  9. #169
    Jan 2009
    396
    I wish I can go to Poland and see master Bartuss at work!
    But the those hollow steel isn't perfectly straight and have the same thickness do you need to grind it down to make it perfectly level and straight?
  10. #170
    Feb 2010
    202
  11. #171
    Mar 2006
    489
    Dosen't really look ready to me, unless it's manually controlled...
    That's the strangest z-axis setup I've ever seen. Why did you go that way?
  12. #172
    Feb 2010
    3447
    very interesting! That right triangle must make a pretty rock solid Z axis. I also have never seen that. That is pretty cool.
  13. #173
    Feb 2010
    202
    Smile
    it is manually, the client just wanted to working to copy the flasks guns.
    Z-axis has a counterweight, very little work
  14. #174
    Oct 2007
    123
    Hi Bartuss
    I have great admiration for your work! Nice stuff!
    on that big 5 axis machine, did you have a brake or counterweight on the Z axis? or Does the self locking trap. screw do all the work? If so, the 50Nm stepper (that's about 7,000 oz-in) has to overcome the friction of the self lock as well? One more Q: What nema size are the frames are the 28 & 50Nm motors?
    Just FYI if you're interested, I'm doing a 5 axis build here:
    http://www.cnczone.com/forums/showthread.php?t=110480
    & here:
    http://www.calvinodesign.com/90037/9...01/BuildLog06/
    I like the idea of the counterweight that you did with the red & blue machine.
    I'm working on a way to keep position on the Z when power is off.
    What do you think about a spring for the Z axis counterweight? Or a power-off brake?
    Nice work man! Cheers!
  15. #175
    Feb 2010
    202
  16. #176
    Nov 2010
    I am looking a trying to build a similar sized machine, but I have a few questions to ask. (ways=linear bearing)
    1) What positional accuracy could you hold with this machine? .001" .010" or .100"?
    2) How do you ensure the X axis ways are parrallel to each other. Considering they are so far away, wouldn't it take expensive equipment to get this tolerance to less than .010"?
    3) How do you ensure X, Y, ans Z axes are perpindicular to each other? I know in more expensive machines a laser system is used, but I am wondering how one would do it on a budget.
    4) Did you shim the ways when you mounted them to ensure that it would not be wavy? i.e. if what you bolt them to is wavy then they the machine wil be wavy unless you use shims or precision machining.
    If you cant tell I am trying to figure out how you trued this machine without special equipment. If you have any advice it would be greatly appreciated
  17. #177
    Mar 2004
    439
    steigcm-
    After spending 10+ years designing and building high precision gantry machines for silicon wafer and LCD production, you are correct, it usually takes lasers and other expensive equipment to get a machine true and accurate. However, if you have more time and patience than money, it can still be done.
    Some tricks:
    1.) Start with the "Main Rail" - and concentrate on getting it straight and flat. One of the least expensive ways to do that is by using an autocollimator. Sometimes they can be found for a good price on ebay. This will tell you angular error in two directions at the same time (pitch and yaw) of the bearing block as you move it over it's travel. Start from one end and work your way down. Alternately, you can look for a qualified straight edge or as large of a granite/cast iron surface plate as you can safely handle/position. Then, mount an indicator to the bearing block and indicate to the surface of the granite. You will need to set this up twice, as you can only measure straightness or flatness of one axis at a time. If your travel exceeds the length of the granite/cast iron, you can start at one end, and move the granite down the travel by about 1/2 the granite's length each time. That way you can use the first 1/2 the travel to realign the granite to the tightened rail, and the other half to align the rail.
    2.) Add the second rail - You can mount an indicator on the "Main Rail" and use it to indicate in the second rail for both straightness and flatness - but they may be at different heights... One way to solve this would be to set up the granite surface plate in the middle of the machine, and use an indicator with a long reach to align the plane of the granite to the first rail. Then you can rotate the indicator across to the other rail and adjust it until it is the same height. Then use the main rail to align the second rail.
    3.) Squaring up travels - once you have your machine assembled and under power, and each axis is straight and flat, you still don't know if they are square to each other. This is usually most easily accomplished with a large precision square, but diagonal measurements at the extremes of travel also works very well. Start with a small precision square to get you close in all directions - X/Y, X/Z and Y/Z. Otherwise, the cosine errors will really cause frustration! For a large router you could use a tape measure, but for a more accurate machine consider buying or making a crazy-long caliper extension. Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies It's not the actual length of the diagonal measurement that is critical, but the difference between them. If you make a caliper extension, it does not have to be a precision length - again, it is the difference between the measurements that matters. Use trig to calculate how far out of square the axes are, and adjust from there. The easiest way to measure this would be to mount some material to the extremes of travel, drill some holes at the 4 extremes of travel and measure diagonally between the holes. It'll likely take a few iterations to get it right. You can also use this trick on more than just the X/Y travel - as long as you have some way of making a hole or precision mark you can measure to. You could use a temporary spindle, or you could simply mount a sharp point to scribe a surface and measure across the marks.
    I hope this helps - These are the same procedures as are done with laser interferometers, just on a budget.
    Let me know if you have additional questions.
    Keith
    NEATman
    Basic research is what I'm doing when I don't know what I'm doing. Wernher von Braun
  18. #178
    Feb 2010
    3447
    You need to do a full write up article on this!! This is pretty much amazing info!!! In my large machine im partially stumped on how to square it all up. This should prove helpful!! Check out the link to my build if you have time, it would greatly be appreciated!!
    http://www.cnczone.com/forums/genera...*rebuild*.html
    Thanks!
    Quote Originally Posted by NEATman View Post
    steigcm-
    Some tricks:
    Keith
  19. #179
    Feb 2010
    202
  20. #180
    Dec 2010
    337
    just caught this thread , holys""t nice machine..
    you could always sleep in it if your girlfriends chuck you out
Page 9 of 10 78910
  1. 5aXis-USB-iso-BOB
    By Yachaan in forum Open Source Controller Boards
    Last Post: 09-20-2015, 05:48 PM
  2. Semi - DIY CNC Router / Mill Project Build (With photos)
    By rescueweasel in forum CNC Wood Router Project Log
    Last Post: 08-30-2014, 06:21 PM
  3. 5axis help
    By BOATDUDEGUY in forum Mach Software (ArtSoft software)
    Last Post: 02-24-2014, 08:08 PM
  4. My CNC build-up with video and photos + everything a beginner should know
    By dmoore in forum DIY CNC Router Table Machines
    Last Post: 02-07-2008, 02:53 AM
  5. 5axis Help
    By jybute in forum Haas Mills
    Last Post: 11-22-2006, 03:10 PM
