587,221 active members*
3,079 visitors online*
Results 1 to 5 of 5
    Apr 2005
    131
    Exclamation THK linear slides
    Hi, I would like to know if all blocks for THK RSR 12 will fit on the 12 LM rails?
    I got 2 RSR12w blocks on 48 inches rails but need 2 more blocks to construct the machine. All I can find are RSR 12X on a 5 inch rail. Would these fit?
    Para
    Paraman, Parabeast, Paramachine, Parameter.
    The many in one and the one in the many.
    Nov 2010
    I worked recently with a THK engineer and I was impressed by the range and numerous types of linear rails. I think you should contact THK for advise because there are so many minor differences between similar products.
    It would be a mistake to assemble rails that are not compatible and the THK guy had a product manual as big as a telephone directory.
    Jun 2004
    6618
    You can actually go to the THK website and do a little searching. Look for the blocks and then it will show you what type rails will work with particular blocks.
    I had a similar things with some 25's and the rails fit three different type blocks that I had, so chances are the may fit. I had some others though that were wide rails. If that W stands for wide, you may be outta luck.
    Product Info TOP [ THK || USA ]
    Lee
    Apr 2005
    131
    THK linear slides
    Well, thanks guys. I opened an account with THK and asked them directly. I'll just have to wait for their reply.
    Jun 2004
    6618
    I did a bit of looking around there on the site and W does mean wide. I could not find the X in an RSR model number though, but without a W, I doubt they would fit.
    Lee
  1. Two different types of linear slides? Why?
    By DingbatCA in forum Community Club House
    Last Post: 08-24-2009, 03:09 AM
  2. Linear Slides from PBC Linear Assembled in Underwater Drill
    By Pacific Bearing in forum News Announcements
    Last Post: 06-24-2009, 08:54 PM
  3. How do the linear slides stack up?
    By jsage in forum Linear and Rotary Motion
    Last Post: 01-30-2007, 11:57 PM
  4. Linear Slides
    By pbunnstf in forum DIY CNC Router Table Machines
    Last Post: 07-19-2006, 02:47 AM
  5. Linear Slides v/s rail slides
    By bryanrabb in forum DIY CNC Router Table Machines
    Last Post: 03-28-2006, 03:45 AM
