587,086 active members*
2,878 visitors online*
Results 1 to 3 of 3
    Dec 2010
    Exclamation Cylinder Head Porting
    Hi i'm new. I am currently starting a Cylinder head Porting project. I have previously ported an 8V VW head very basically. The head i will be porting now is a 16V 1.6 Zetec. I would like some advice on how to get the best flow throught the ports. I have acess to a Superflow Flowbench and all the tools required for porting.
    Heres some moulds i took.
    Intake:
    Uploaded with ImageShack.us
    Exhaust:
    The actual Head :
    Cheers
    Apr 2009
    144
    I am assuming this is being done manually with a die grinder and long reach burrs, stones and drums? Or are you CNC porting this head? I always just do a quick and easy gasket match port and polish job. Worry more about smoothness than port size to maximize flow.
    The castings are cool, are you just using them as a guide for your port job?
    This guide is old, and I like using burrs better than grinding stones and sanding drums, but I think it is a pretty good general outline.
    http://65corvette.nonethewiser.net/t...al/diyport.pdf
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
    Jan 2006
    481
    Hi Fitzi74 , jion this forum PTS Flowbench Forum - Index page
    cheers
  1. P&W R-985 Wasp Jr. 1/6th scale - Cylinder head drawings?
    By ninefinger in forum I.C. Engines
    Last Post: 07-29-2023, 09:28 PM
  2. What type of do I need for head porting?
    By hotturbine in forum Want To Buy...Need help!
    Last Post: 10-22-2012, 10:27 AM
  3. CNC head porting.. Diy???
    By Zriuz in forum I.C. Engines
    Last Post: 03-08-2010, 03:52 AM
  4. 65cc Chainsaw Cylinder/head
    By crayner in forum I.C. Engines
    Last Post: 12-06-2007, 02:42 AM
  5. Casting a cylinder head
    By hammers in forum Casting Metals
    Last Post: 08-24-2007, 12:22 PM
