587,515 active members*
2,934 visitors online*
Results 1 to 1 of 1
    Jun 2003
    446
    NEW BobART PRO-X from BobCAD-CAM
    BobART PRO-X gives the operator the flexibility to automatically convert a color, grayscale or black and white picture into a full relief model and then create the right machine toolpath strategy that they need on the fly. Added mirroring options allow you to create negative relief models fast. Not only does the BobART PRO-X solve the barriers of creating custom relief or embossed models directly from a picture, it allows you to perform advanced raster to vector operations to create 2D profile toolpath for carving or profile milling directly from pictures with ease. True to BobCAD-CAM tradition, BobART PRO-X has been developed to make the embossing process smooth and easy enough that even the most novice operator can pick it up fast. The added tools and boundary control cutting options for making your toolpath are giant steps above earlier versions of BobART. Once the toolpath is machined in the CAM end of the BobCAD-CAM V20 software you can simulate and verify the cutting process before actually sending the program to your machine. The cost is amazingly affordable enough that just about anyone can have it. Check this new product out at www.bobcad.com.
