A 2004 HRT160 that is white in color and has the two cables to connect is brushless am I right?
Hercules
2008 TM-1, 2008 TL-3, 2009 TL-1, 2010 VF-2YT
Yes, 2 cables connecting at the cabinet is a brushless rotary.
I have a rotary question too :
I have a rotary axis that has a name on it " HRT 310 H " a big gray one `08 , but I can not find that name on the 4th axis settings screen , I have either " HRT310 PL" or "HRT310B" which I believe B stands for Brushed , so I set the first one, but when the rotary is rotating I get about 100% or sometimes more of A axis load, is this normal ?
I didn`t join the air for brake .
Peter
I'm not sure but I think the air is used to release the brake. That would explain why your load is 100% or higher.
Ralph
The correct setting for an HRT310 H is HRT310. The H refers to the style of motor.
Thanks,
Ken Foulks
