587,848 active members*
3,141 visitors online*
Results 1 to 5 of 5
    Jan 2008
    123
    760-22 x axis problem
    I have a 760-22 that has a tight x axis Probably a year maybe more ago Machinetek had posted about shimming the plates that go under the ways I did this and the machine ran great until a month ago I found the oil line to the ball screw broken and replaced it The mill ran good for about 2 weeks but the ballscrew is tight again I have also cleaned and regreased the thrust bearings on each end of the screw They looked to be in good condition
    The ball screw looks smooth and shiney I guess I'm to the end of my knowledge which isn't all that far Any help would be appreciated
    Nov 2004
    3028
    Back to square one. You do not know what the issue is so loosen the screws on the X axis keeper plates a turn and see if it frees up. Go from there.
    George
    Jan 2008
    123
    Loosened the front keeper plate and tried to turn the ballscrew by hand it turned snug for a bit then freed up so I tried to retighten the plate and the screw got a little tighter but nothing like before I loosened the plate I can still turn it by hand
    I cut a strip of .001" shim stock ,loosened the plate and inserted the strip between the way and the turcite plate on the left end it pulls out with slight resistance on the right end it will pull out but has a lot of resistance so I guess I have slightly less than .001" clearence I'm confused as to how the screw can free up so easily after it was so tight and then is still be free when I tighten the plate back up
    Tom
    Nov 2010
    your ballscrew could be damaged, it is not good practice to shim things unless you have measures the clearances. With a good axis it should be possible, without the motor, to turn the ballscrew freely by hand.
    Good suggestion to put things back as they were originally and go from there.
    Nov 2009
    58
    on all my 760's we can turn x & y by hand with motors off. i think your ball screw may be damaged, if its very shiny its prob worn.
    I've heard they don't do well without way oil for very long.
  1. Z Axis Problem - please help
    By topduck in forum Taig Mills / Lathes
    Last Post: 03-17-2010, 04:35 AM
  2. .001 Z Axis Problem
    By BlueFin in forum Tormach Personal CNC Mill
    Last Post: 12-08-2008, 03:41 AM
  3. axis problem
    By bbrown2005 in forum Mach Mill
    Last Post: 09-09-2008, 12:43 AM
  4. ref axis problem
    By destro in forum Machines running Mach Software
    Last Post: 06-28-2008, 05:25 PM
  5. Problem with Z axis
    By MagTDK in forum DIY CNC Router Table Machines
    Last Post: 11-01-2006, 03:12 AM
