587,711 active members*
4,072 visitors online*
Results 1 to 20 of 20
Threaded View
  1. #13
    Dec 2009
    32
    ok,
    I ran the motor test, both on ac and bldc, and both ways it tells me it found 2170 which is correct for a 4 pole motor. I then ran the moveabs command with both 4 pole and 6 pole setting. On the 4 pole setting, the motor started to move and then locked. With a 6 pole setting, the motor spun up to a very high speed. So, I believe the motor is ok with the 6 pole setting, even though the test configuration seems to think 4 poles is correct.
    I did some more tests, with some different gains and current limits. Attached are a couple of these plots. Maybe they will provide some insight. Both are from the 6 pole setting.
    Attached Files Attached Files
  1. Program Recovery
    By daveyddd in forum Haas Lathes
    Last Post: 04-12-2012, 08:50 PM
  2. Following Error and Recovery
    By vegipete in forum CNC Machine Related Electronics
    Last Post: 11-13-2011, 07:22 PM
  3. DMG turret recovery
    By turner13 in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2011, 09:56 AM
  4. PROGRAM RECOVERY
    By DAVE LEMON in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-24-2011, 09:19 PM
  5. MC510VG TC Recovery Help
    By haastec in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2011, 06:42 PM
