Originally Posted by
swain
....I ran a job a while back of 800 units, with about 10 pieces per unit being made from .5 brass round material when the machine was converted. With 8000 pushes, I would have to say 20 or less service calls due to the bar feeder messing up. The hardest thing to figure out was to keep new plastic washers in the push tube so that the material would not "slide" past the push point....using the washers as traction so material would stop when the push rod did.......Swain
I was reading through these posts and this caught my eye. Do you mean that during the run of 8000 parts you had 20 service calls on the Servo 300? In other words an average of 400 pushes per service call?
Surely not!
Also to solve your sliding past the push point why not push to a stop? We have several shop-built hydraulic barfeeds that work this way. They did not cost us 6 grand apiece and they do a lot more than 400 pushes before needing servicing.
