587,089 active members*
2,873 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Change Battery on Maho 600E, Phillips 432
Results 1 to 5 of 5
    Oct 2003
    192
    The 6 Volt battery was installed 9 years ago, figured it would be time to change
    and do it myself, not sure anymore if my memory is correct...change when machine
    is on, ..right? Oh..does this make sense?..when cabinet door is opened, isn't the
    machine off....it's been a while.
    First make sure you have current backup of the machines parameters!!!!
    Yes must be changed with power on!
    Regards
    DD
    Oct 2003
    192
    Thank you DD!
    How would I do that to check for current to parameter?
    Wouldn't there be current when power in on?
    Do you have a RS232 hooked up to a computer?
    Regards
    DD
    Oct 2003
    192
    Only when machine is on and I run cad cam, otherwise it's unplugged because one time lightning fried one board and PC...that was a expensive bill.
  1. Maho MH 800E (CNC 432 Phillips)
    By kotten1 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-29-2016, 12:24 PM
  2. Maho Phillips 432 manuals?
    By HKgunslinger in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2012, 06:09 AM
  3. Drip feed with MAHO 600E-Phillips cnc432
    By Grusse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-20-2010, 09:52 AM
  4. Maho 400E or 600E
    By HKgunslinger in forum Want To Buy...Need help!
    Last Post: 11-10-2008, 02:12 AM
  5. Maho Mh 1000c C/w Phillips 432-20
    By SIMONB in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-06-2008, 10:13 AM
