I have to agree with the above post.
I found it easier to create four separate programs for the machine.
Turning in Spindle -1
Then the Milling in Spindle -1
Transfer from Spdl-1 to Spdl-2
Turning in Spindle -2
Then Milling in Spindle -2
Remember that you will be working in Planes G17, G18, & G19 so be sure you call the appropriate Plane like G18 for your Turning, G17 for Face Drilling/Milling, and G19 for Side Milling/Drilling.
It is also wise to call all your G-Modals for every Tool.
Programming can get a little hairy.
O2604(K26150-0-4 DISC TOP REV.-E)
(ALM 6061-T6 3.0"D)
(OFC 2.2")
(B-AXIS STROKE 2.095)
(S-PGM O5556 CUT REMNENT)
(SET LNS FOR PART OAL +.02 + C/O)
(LNS SUB-SBDL SETTING)
G330G99G54G18G0M200
G28U0V0M46
G28W0M69
(G53X-2.Z-14.M46)
(G28V0M69)
M1
(2/M98P5555 BAR LOAD S-PGM-1)
(2/M98P5556 BAR LOAD S-PGM-2)
N1(T101 CNMG431 TIP-3)
T0101M8
G28V0
M69
G330G99G54G40G18G0M46
G50S2000
G96S1000M3
G0Z.05
X3.1
G41G1X-.01F.01
G0Z.1
X3.1
Z.01
G1X-.01
G40G0Z.02
G42X3.05
G71U.1R.02
G71P100Q101U.006W.003F.012
N100G0X1.095
G1X1.375Z-.12F.003
Z-1.312F.006
G2X1.501Z-1.375R.063
G1X2.95
X2.98Z-1.39
Z-2.1
N101X3.05
G40G0Z.1M9
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N2(T202DRILL 7/16.437"D)
T0202M8
G28V0M46
G330G99G54G40G18G0M69
G97S1200M3
G0Z.15
X0.
G1Z-.525F.006
G0W.01
G1Z-1.05
G0W.01
G1Z-1.575
G0W.01
G1Z-2.1
G0Z.15
X3.05M9
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N3(T303 F-F/T CNMG431 TIP-3)
T0303M8
G28V0M46
G50S2000
G96S1200M3
G41G0Z.1
X1.4
G1Z0.F.01
X.3F.005
G0X3.05Z.02
G70P100Q101
G40G0Z.1M9
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N4(T404 NPT 1/4-18)
T0404M8
G28V0M46
G330G99G54G18G0M69
G97S100M3
G0Z.5
X0.
G1Z-.565F.055556
M5
G1Z.5F.05556M4
G0X3.1M9
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M5
M1
N5(T505 C-AXIS CROSS DRILL 7/16D COB STB 135SPT)
T0505M8
M5
M69
G330G98G54G40G19G0M45
G28V0H0
G0Y0
G97S2500M14(CCW ROTATION FOR 180DEG. C-AXIS TOOLS)
G0Z.6
X3.2
C0.
Z-.875
X1.5
G87X.03Q1000R0.F15.M68
G0X3.2M5
Z.6M9
M46
M69
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N6(T707 C-AXIS CROSS TAP NPT 1/4-18 HSS)
T0707M8
M5
M69
G28V0H0
G0Y0
G97
G0Z.6
X3.2
C0.
Z-.875
X2.75
G99
M329S150
G88X-.015R0.F.055556M68
G0X3.2M5
Z.6M9
M46
M69
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N703(T303 DEBURR 1.375 O.D. CNMG431 TIP-3)
T0303M8
G28V0M46
G50S2000
G96S1200M3
G0Z.1
G42X3.05
G1X1.375F.01
Z-1.3F.005
X1.475F.01
G40G0X3.05Z.1M9
G28U0V0M5
G28W0
(G53X-2.)
(G53Z-14.)
M1
N7(C-AXIS FACE SPOT 3/8D 90DEG. HSS)
T0606M8
M5
M69
G330G98G54G40G17G0M45
G28V0H0
G0Y0
G97S2500M13(CW ROTATION FOR FACE LIVE TOOLS)
G0Z.1
X3.1
C60.
X2.524(B.C. 2.524D)
Z-1.275
G83Z-1.515R0.F15.M68
C180.
C300.
G80G0Z.1M5
X3.1M9
G28U0V0M69
G28W0M46
(G53X-2.)
(G53Z-14.)
M1
N8(C-AXIS FACE DRILL .265D JBR HSS 118SPT)
T0808M8
M5
M69
G28V0H0
G0Y0
G97S1500M13(CW ROTATION FOR FACE LIVE TOOLS)
G0Z.1
X3.1
C60.
X2.524(B.C. 2.524D)
Z-1.275
G83Z-1.975R0.Q2500F7.5M68
C180.Q2500
C300.Q2500
G80G0Z.1M5
X3.1M9
G28U0V0M69
G28W0M46
(G53X-2.)
(G53Z-14.)
M1
N9(TRANSFER, W0.1560, T1010)
T1010M9
M5
G330G98G54G40G18G0M46
M211
G28V0
G28U0
G0Z.025
M51
M251
G97S200M3
M35
G0B1.5
G4U.5
G1B.1F20.
M59
M259
G38B0.K.001F1.Q.05
G4U.5
M210
G4U1.
M11
G4U1.
G1B2.095F20.
G4U.5
M10
G4U.5
G97S400
G99
X3.15
M8
G1X3.1F.01
X3.02F.003
G75 R.01
G75 X-.01 I.05 F.004
G0X3.2
G28U0M9
G0Z.025M5
M51
M251
M80
G330M36
M59
M259
G28U0V0
G28W0
(G0G53Z-14.)
M1
N10(T0117 SPDL-2 R-F/C CNMG432 TIP-4)
T0117M8
M246
G28V0M269
G330G99G55G40G18G0
G50S2000
G96S1000M203
G0Z-.1
G42X3.05
G72W.02R.02
G72P1010Q1011U.005W.002F.01
N1010G0Z.03
G1X2.98F.002
Z.02
X2.94Z0.
X0.
N1011Z-.1
G40G0Z-.15M9
X3.05
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N11(T0420 SPDL-2 R-BORE CIRCLE 3/8D)
(CCMT-2-1.5-0.5 TNR.008 TIP-1)
T0420M8
G28V0M246
G50S1500M269
G96S650M203
G330G99G55G40G18G0Z-.1
G42X.425
G71U.025R.01
G71P1111Q1112U-.005W-.002F.008
N1111G0X2.151
G1X1.921Z.015F.002
Z.378F.004
X.46F.003
X.43Z.393F.002
N1112X.425
G40G0Z-.1
G42X.425
G70P1111Q1112
G40G0Z-.15M9
X3.05
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N12(T0319 SPDL-2 F-F/C CNMG432 TIP-4)
T0319M8
M246
G28V0M269
G330G99G55G40G18G0
G50S2000
G96S1000M203
G0Z-.1
G42X3.05
G70P1010Q1011
G40G0Z-.15M9
X3.05
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N13(T0622 SPDL-2 F-BORE CIRCLE 3/8D)
T0622M8
G28V0M246
G50S1500M269
G96S650M203
G42X.425
G71U.025R.01
N1111G0X2.151
G1X1.921Z.015F.002
Z.378F.004
X.46F.003
X.43Z.393F.002
N1112X.425
G40G0Z-.1
G42X.425
G70P1111Q1112
G40G0Z-.15M9
X3.05
G28U0V0
G28W0
(G53X-2.)
(G53Z-14.)
M1
N14(T0824 SPDL-2 R/F- I.D. GROOVE .101W ISCAR 3/4D SHK)
T0824M8
G28V0M246
G50S1000M269
G96S150M203
X1.8
G1Z.205F.02
(G75R.01)
(G75X2.027I.025F.003)
G1X1.9F.005
G1X1.961F.003
X1.955
X1.991
X1.988
X2.01
X2.008
X2.0275
G4U.5
G0X1.8
G97S580
Z.191
G1X1.921F.003
X1.941Z.201
X2.0275
G4U.5
G0X1.8
G1Z.22F.01
X1.9
X1.921F.003
X1.941Z.21
X2.0275
X2.025
G97S450
X2.0285F.001
Z.2015F.001
G0X1.8
Z-.15M9
G0X3.05
G28U0V0
G28W0M5
(G53X-2.)
(G53Z-14.)
M1
N15(UNLOAD PART SPDL-2)
T0101M5
G28U0V0
G28W0
M73
B-12.8
M47
G4U.5
M74
G0G330
M30(M99 TO LOOP)
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
