587,311 active members*
3,484 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Reasons NOT to buy RhinoCAM!
Page 2 of 3 123
Results 21 to 40 of 43
  1. #21
    Apr 2006
    59
    IBM once had millions of customers worldwide too; where are they now?
    I think you should be thankful that you have a customer that gives you feedback - however he gives it.
  2. #22
    Jun 2008
    1082
    Quote Originally Posted by fretsman View Post
    Hirudin, was this ever resolved? I'm also looking for a Cam program for Rhino 4.0 and was curious to know if this now works for you since you have a Taig like I do.
    Thanks,
    Dave
    I responded to your PM as well fretsman, but I'm not sure if you got it...
    If I haven't said this already: I don't exactly "hate" Mecsoft or RhinoCAM. After starting this thread I tried some of the competition and I can't say I'm impressed with the other offerings in this price range either. I won't get into specifics here, but I'll say that I tried (and didn't like) SprutCAM, OneCNC, DolphinCAM, and probably a couple others. I'm no programmer but I cannot figure out why the vast majority of CAM software I've tried is so crappy AND so expensive.
    My problems haven't been resolved, but I also haven't called their tech support. Of course, I did try to get my problem addressed without directly involving Mecsoft by posting on their user forum. Instead of helping me they banned me because I wouldn't address some inane questions.
    I think the biggest problem I had was that files wouldn't always save properly. The Rhino data would be saved fine but the majority of the time the RhinoCAM operations would NOT. I'm pretty sure there has been an update to RhinoCAM since then but the problem persists. A work around for this is to open two instances of Rhino. After saving the file in instance #1 go to instance #2 and open the file. If #2 doesn't have the RhinoCAM data go back to #1 and save again. Repeat until the file saves properly. I've had to do this eight times in a row before it worked.
    I've since found another glaring problem with RhinoCAM. One way or another it interferes with LOADING of files as well. This time I made a video showing the problem...
    [ame="http://www.youtube.com/watch?v=UB0vG_uxx74"]YouTube- MVI 6184[/ame]
  3. #23
    Jun 2008
    1082
    Quote Originally Posted by nini View Post
    While I am very new to cnc machining, I have a couple of thoughts. First, in my search for a cnc machine, every major manufacturer that I talked with recommended Rhino and Rhinocam for my business needs.
    I suspect this is based on how good Rhino is, not RhinoCAM. If they were suggesting the two based on RhinoCAM's merits I would expect them to suggest VisualMill.
    Rhino is a very good program. It's probably my favorite piece of software. Personally, if I were Robert McNeel I would get my lawyers to send MecSoft a letter requesting they stop using my product's name.
    After reading the back and forth discussion, I must say that I applaud MecSoft's final response. Fustrated or not, failing to work with Mecsoft to alleviate problems is at a minimum, very suspicious. Looks to me like a back door attempt to discredit Mecsoft without credibility.
    Think what you must. Keep in mind that I DID attempt work with MecSoft FIRST via their forum. Instead of offering help they banned me from their forum.
    As I implied in my post above: RhinoCAM may be the best in its price range, but that doesn't mean it doesn't suck. I hope it works well for you! Just make sure you don't accidentally delete one or many of your ops, as there's no undo (you know, unlike "Paint" had when Windows 95 came out).
    Quote Originally Posted by spoiledbrat View Post
    To anyone considering RhinoCam:
    I have been using Rhinocam for nearly 5 years. I have had limited exposure to other cam software, and I can say without a doubt that I will be using Rhinocam for years to come. Many of the problems listed in the origional post have never happened to me.
    Almost everything in my OP is a design flaw. I admit that I haven't tried "Ctrl + C" in RhinoCAM with my new keyboard yet though. If you're not encountering the same problems because you're not using keyboard shortcuts that's not my problem.
    I use this software for simple 2.5D operations, as well as complex 3d and 4th axis projects, with nothing but good results. I would challenge anyone having this many problems to take a minute, and learn the software. I have placed impossible parameters into the Parameters page, and guess what? It could not compute. Junk in, Junk out.
    If I could only learn how to make one window not "always on top" so that I can access a different part of the program. You're right though, I did learn that of the two formats offered for saving tools that only one actually saves everything. The fact that the default choice is the insufficient choice still eludes me.
    I guess I slightly offended that someone can make such outrageous claims about a product that truly delivers. I have called tech support before with issues, that were solved by learning more about the software. From a FRIENDLY STAFF.
    If I disagree with the way an interface is set up, and the company outright refuses to spend tens of thousands of dollars to "fix" the software on my whim, do I have the right to a refund?
    Whatever.
    A "right" to a refund? No.
    A "right" to speak your opinion and hopefully dissuade people from buying a program based on the marketing hype alone? Yes.
    Sorry, I try not to let myself get caught up in confirmation bias. If I spend nearly a grand on a piece of software written by a company that rarely fixes bugs (on my whim or yours) you bet I'm going to make myself heard.
    Quote Originally Posted by daisydog View Post
    Without going into great detail I can tell you Mecsoft is very thorough, polite, prompt and professional with their support.
    Joe Ddog
    I agree with spiked3,
    Quote Originally Posted by spiked3 View Post
    support was typical software support where you received canned answers with little or no thought put into what the problem really was...
    Me: This tool doesn't work the way it should
    Them: Use this other tool
    Me: But I'd like to use this too, it's one reason I bought this software in the first place
    Them: Here, try this work-around
    Me: Again, I want to use the tool designed for this job
    Them: You're banned
    Customer support is only adequate if they merely help you ignore problems or encounter them less frequently. For me to rave about customer support they have to actually FIX the problems they're aware of.
    I use the GIMP (freeware 2D image editor). Is the program perfect? Hell no. BUT it was free! Pretty hard to complain about free software. I also use Directory Opus. Was it free? Not even close. But they constantly update it. Pretty hard to complain about expensive software that always works.
  4. #24
    Jun 2008
    1082
    Well isn't my face red?
    One of the times RhinoCAM caused Rhino to freeze Rhino popped up an error reporting dialog that asked me to describe what I was doing when the crash occurred. This dialog appeared before I had figured out it was RhinoCAM. I typed a short sentence expressing my frustration, but didn't actually describe my problem (I was pretty pissed at the time).
    Rhino got back to me later in the day. Although I had figured out the cause of the issue by then the Rhino rep had suggested that it may be related to RhinoCAM and told me how to check. I replied that it was indeed the RhinoCAM plugin and among other things sent him a link to the video. The person at Rhino forwarded our e-mails to RhinoCAM who promptly figured out the problem and apparently fixed it... within a few hours. That's pretty amazing!
    I haven't tried the pre-release update they sent me yet, but for the time being I'm going to assume that it works*. I'll update this thread again after I know for sure.
    Although I still have some issues with the UI of RhinoCAM I guess I have to change my opinion regarding their willingness to fix problems.
    * I applied the fix and it did indeed solve the problem, the file that wouldn't open before now opens just fine. I also tried a couple files that had caused me problems in the past (they would take ~5 - ~10 minutes to open) - they now open within a second or two.
    For kicks I tried saving a quick file, unfortunately the fix didn't fix the problem as well, but it wasn't suppose to so with regard to the specific saving issue I'm neither better nor worse than I was before, but I have a renewed optimism that I wont have to live with the problem for much longer.
  5. #25
    May 2005
    387
    It's threads like this that....
    ... reinforce a decision made.
    I have Rhino 4.0 with all current updates and service packs. I have been looking for a "reasonable" 4th axis capable CAM package to compliment my laser scanner and CNC Router. Seems most companies require you to buy their "Mill" program at the most expensive level, if you want 4th axis capability. Few offer stand-alone 4th axis programs.
    I am in contact with a number of vendors, each wanting to do an online demo. I downloaded RhinoCAM to test in advance. Now, mind you, I didn't like the fact that I have to purchase RhinoCAM 1.0 in order to then buy RhinoCAM 2.0. That would have had a significant impact on my decision process but what sealed the decision was the fact that, after numerous attempts, I could not get RhinoCAM to accept a simple change from MM to Inches. I was even willing to tolerate the occasional lock-up between Rhino and RhinoCAM... but not accepting a simple change from MM to Inch?! And this from a CAM package that touts the "benefits" of operating from "within Rhino."
    I have AutoDesk Inventor, AutoCAD, Mechanical Desktop, Rhino, Flamingo, Aspire and a number of other programs. I believe I have reasonable expectations relative to what a program "should" do vs. what it does. I applaud those that have copies of RhinoCAM that work flawlessly first time, every time. May it continue to be so. Needless to say, I uninstalled the RhinoCAM plug-in and will continue my search.
    All said, I use my AutoDesk QuickCAD more than any other program... and it only cost $49 seven years ago... go figure.
  6. #26
    Jan 2010
    2
    Ok, here is our official response from MecSoft Support
    Ok, it looks like this thread seems to be collecting people who have some gripe against RhinoCAM either because of ignorance or malice or whatever other reason. I work in the Technical Support department at MecSoft and I would like to post a point by point rebuttal to Hirudin's original posting to dispel any erroneous notions about RhinoCAM 2.0.
    I would also like to take this opportunity to state that our technical support is one of the best in the industry and we fully stand behind our products. I am proud to state categorically that Rhino + RhinoCAM 2.0 is the best value that you can get for your money in the CAD/CAM industry today.
    Quote Originally Posted by Hirudin View Post
    This program is worse than freeware in MANY respects! Gee, I wish I didn't spend $900 on this thing.
    1. For some reason, you cannot copy and paste toolpaths using Ctrl + C and Ctrl + V. Yes, apparently MecSoft hasn't really caught up to Windows 3.1 yet.
    This is totally incorrect. Anybody can verify this by downloading our RhinoCAM demo from http://www.mecsoft.com/DownloadDemosc.shtml, loading a tutorials file that has Machining Operations (Mops) defined and going through this sequence.
    Bring up the Mops Browser Window
    Select a Mop and make sure it is highlighted
    Press Ctrl + C
    Press Ctrl + V
    You should see another Mop with a -1 appended to its name. In fact before we used to append a (1) to the name when the user did this but having a ( or ) in the name of an operation caused problems with some old controllers and so we had to switch this to a -1. This functionality has been present in the product since its inception.
    2. You cannot undo changes made to your toolpaths. Even though the keyboard shortcuts for copy and paste are not enabled, accidentally hitting the delete key will permanently erase your work.
    Deleting a Mop will put the Mop in the clipboard. You can then retrieve the operation by doing a right click and paste operation. Or a Ctrl + V will also work – irrespective of what was stated in item 1 above.
    3. Loading tools is cumbersome. Tool Libraries can be saved into two different types of files for some reason. The standard type does not save the tools' speeds and feeds (of course, RhinoCAM doesn't warn you about this). If you want to really save your library you need to use the other file format.
    This is there for legacy reasons. In RhinoCAM 1.0 we did not save feeds/speeds in the tool library. In 2.0 we have introduced this feature but decided to keep the old format around so our 1.0 users would be able to load these old libraries and save them in the new format. This older format will be phased out in our next release.
    4. Toolpath creation methods do not work. Check out this thread on the RhinoCAM forum where I pointed this out to them...
    http://www.mecsoft.com/phpbb/viewtopic.php?p=6276
    As you can see in the thread we tried to contact Hirudin without avail. For some reason he does not want to directly deal with us – which would have made a lot of sense in this case since we were trying to understand why he was having so much trouble with the software. Trying to figure out what he wanted our system to do without information, as any reasonable person can see from this thread, is near impossible. That is why we offer FREE phone support to all our customers. We love hearing from our customers and the more information we have the better we can help you. So pick up the phone and give us a call if the support we offer through our Support Forums is not helping you.
    5a. The software is buggy. I've had Rhino crash on me about 6 times while working with RhinoCAM. I've never had it crash before.
    Recently a new bug has shown up where it DOES NOT SAVE YOUR WORK about 50% of the time.
    This is blatantly untrue. We cannot duplicate this nor have we heard of this from our customers. This is such a fundamental feature of the product that I am sure we would have heard from at least one other customer from our thousands of customers around the world about this problem if it indeed was a problem.
    5b. They only seem to update RhinoCAM when a new version of Rhino is released.
    Incorrect again, we have released 2 Service Packs for RhinoCAM 1.0 and have released 2 Service Packs for RhinoCAM 2.0. We are currently readying another Service Pack for release.
    6. Bug reports are met with hostility and insults. Check the thread linked above for which I was banned from the MecSoft "Support" Forum.
    Unfortunately you cannot see pictures posted to the MecSoft forum unless you log in. If anyone is interested, I can re-post the pictures here.
    This statement is once again as far from the truth as possible. Our customer support is unparalleled in the industry and we do whatever is reasonably possible to help our customers out. After all we will not be in business without them. We understand this and take this responsibility seriously. However all we ask for from our customers is to help us help him/her. Without this cooperation from the customer we will not be able to do this. Accusing us of hostility is not only untrue but also insulting.
    7. Tool selection is artificially limited. For instance Drilling operations only allow you to select drills and center drills from your tool library. At first this may make sense. But if you're like me and use a "vee mill" to do your spot drilling you're out of luck.
    This is a deliberate design decision on our part. To maintain system integrity we do not resort to quick and dirty solutions even if it might make sense to a “power” user. Decisions such as these are what makes a system unwieldy to use in the long run - if you pack enough of these into a system.
    As an alternative, you can use a V mill and use our engraving option and select a point as your geometry and perform drilling this way with a milling tool. You can even use multiple depth of cuts to simulate peck drilling if you so desire. Another way of doing this is to use the same tool number in a drill tool and use the drilling operation if you desire cycles to come out. The post-processor only looks at the tool number and does not check the type of tool used.
    8. The user interface is unrefined.
    This is a debatable point. There are many users who love our interface and would not trade it for products such as BobCADCAM or MasterCAM.
    For instance, the MOp (machine operations) creation interface is "always on top" (meaning the window is displayed above all other windows, regardless if Rhino is the active program or not. Even minimizing the main Rhino window will not get rid of the MOp creation dialog, neither do clicking the "Show Desktop" button in Windows 7 nor does hitting "WinKey + D" on the keyboard.
    This was a put in based on a user request. However a few users have complained about this and so we have reverted back to the old behavior. This has already been fixed and will show up in our next service pack.
    Another curious UI decision is that MecSoft did not include a way to access the speeds and feeds calculator from the tool creation dialog. If you're in the middle of creating a new tool and you'd like to use the calculator to enter all the different speeds automatically you have to...
    • Save the tool (even though at the moment it's incomplete)
    • Create a new MOp (yes, the only way to get to the calculator is through the MOp dialog)
    • Go into the speeds and feeds tab
    • Click the "Load From Table" button
    • Struggle with the poorly made calculator to get the parameters you want
      THEN
    • Open your newly created tool again
    • Manually copy all the values from the MOp to the tool
    • Save the tool again
      See attached picture
    This is a good point. We will make the feeds/speeds calculator available from the tool creation dialog in our upcoming release.
    9. The simulation mode is very inaccurate, too fast, and too slow - all at the same time.
    Inaccurate - The virtual part is very rough. Sometimes areas that should be round are completely square. Arcs and diagonals are jagged. The display is enough to determine if a profile cut is on the correct side of the line, but not a whole lot more.
    Too Fast - Sometimes the simulation will complete instantly leaving you wondering just how the part will be cut. If you're watching the simulation to find out in what order features are milled you may be out of luck.
    Too Slow - When the part "stock" is displayed it slows my machine to a crawl. My computer isn't the fastest in the world but it's no slouch (Intel Core2Quad @ 2.4GHz (Q6600), 4 GB of DDR3 RAM, nVidia GTX280 video card (1 GB of video memory), OCZ Vertex SSD, running Windows 7 RC1 x64, 2560x1600 display). I get approximately six frames per second when the stock is displayed.
    There are settings in the simulation preferences dialog that the user can set to alleviate all of these issues. In addition to this, if simulation quality is important, we offer two separate 2 simulation algorithms/modes in our product. The use of the right mode in appropriate situations is important for obtaining the desired results.
    10. The program has very few options. The few options it does have will sometimes they'll inexplicably revert to their default settings - without warning. Sometimes my post processor setting will jump to the top of the list, for seemingly no reason. I've also had the "Output arc/spiral/helix as linear segments" options seemingly randomly reselect themselves.
    Our product has one of the richest feature sets in the industry and in our price range, it has THE richest feature set. So this statement shows a lack of understanding of the market as well as the available features in our product.
    Also the settings that the user is talking about are saved in the registry and will not “randomly” change. It is possible that these settings were not saved due to a crash out of Rhino and so these settings were not saved in the registry.
    11. The program checks for updates EVERY TIME IT'S OPENED. This process needs administrator privileges for some reason which means if you're using Vista or Windows 7 you need allow/disallow a UAC window every time the program starts (depending on your UAC settings of course) just to reconfirm MecSoft has not released any updates ([i]see 5b above[/b]).
    You can turn this off if you don’t want the program to check for updates every time the program launches. In fact there is a check box right on the dialog that asks if the user wants to do this every time or not. I am not sure why this user missed this.
    12. Features that were present in RhinoCAM version 1.0 Basic have been removed from RhinoCAM version 2.0 Standard. Want to edit your toolpaths like you did with the old version? That'll be another $3199 to upgrade to PRO.
    This is again an incorrect statement. If we did this, it would not go over very well with our existing customers. Quite to the contrary we have updated and enhanced almost ALL methods that were available in the .10 product. In addition to this we have added new methods such as Spiral and Radial machining in RhinoCAM 2.0 STD version. These methods were only available in the PRO configuration in RhinoCAM version 1.0. So I fail to see what the customer is complaining about here. A specific example would help us get to the bottom of this claim.
    Technical Support Department
    MecSoft Corporation
    [email protected]
  7. #27
    Jan 2010
    2
    Quote Originally Posted by Dave's_Not_Here View Post
    To clarify that RhinoCAM does not accept a simple change from MM to Inch, this is what RhinoCAM does when you change the model from mm to Inch (or vice versa for that matter):
    http://www.youtube.com/MecSoftCorporation
    All programmed operations and tools will be discarded. Since Tools and Mops all have sizes and default values based on the units, that is, are units dependent this is a reasonable way you would expect the system to behave. Note that RhinoCAM cannot prevent the units change from happening (the control is with Rhino) and so it can only react to it.
    MecSoft Corporation
    www.mecsoft.com
  8. #28
    Rhinocam is a bargain and does a lot for the $.
    I have had my share of problems with Rhinocam. I am currently trying to resolve why when curves are chosen for 2.5D Rhinocam won't make tool paths.
    If I could turn back time I would buy Visual Mill rather than Rhinocam and keep it seperate from the CAD function. Hindsight is 20/20.
    Jack
  9. #29
    Mar 2009
    19
    I have Visualmill 6 easy to use and overall quite good for the price and support is very good.
  10. #30
    Apr 2007
    64
    I use RhinoCam to generate toolpath for 6 different machines and various clients. It never failed me, and if I have a problem setting up a difficult piece I know I can call the support guys and get a few very professional hints.
    The mm to inch switch problem is sitting in front if the system. The cause is not IN the system....
    No, I really have a lot of work done in it and the service is top notch, and the software is robust. I often work multiple hours on a larger project and when I finally save the file... it's the first time at all. I'm happy that there was no power failure.... but the software has not let me down a single time.
    Is it complex, yes and no. You have to know 3D cad and then understand the basic concept of RhinoCam. Which is a matter of a couple of hours at max. Then it's experience on how to use the tool path strategies together with your machine.
    So.... with a few hours training or dedicated manual reading, the original post of this thread would not be here.
    Rhino and Rhinocam ROCKS!
    I use the pro version and generate 3, 4, and 5 axis toolpath with Rhinocam.
    Reliably and profitable!
    Lemo
  11. #31
    Jul 2009
    85
    Honestly, Use a program that you like.
    No need to bash it on a public forum.
    I learned Master cam in school and I hate that program. I didn't go to there forum saying how bad it was.
  12. #32
    Jun 2008
    1082
    Hmmm... revisiting this thread after a long hiatus from using my CNC machine. I still have not purchased another CAM package (once bitten twice shy I suppose). Not only that, but the new machine I bought (Novakon NM-200 series 2) is going to come with the RhinoCAM 4th axis plugin. So, in a way I have actually now given MORE of my money to MecSoft despite my problems.
    Quote Originally Posted by MecSoft Support View Post
    Maybe we're talking about two different wings of your support department. I think it's no secret that I did not seek support over the phone. I think the "support" offered on the forum speaks for itself.
    Me: "Hi I have a problem with this tool, it doesn't work."
    Them: "Use this other tool."
    Me: "But I want to use this tool here."
    Them: "We've tried to help you. Enjoy being banned."
    This is totally incorrect. Anybody can verify this by downloading our RhinoCAM demo from CAD Cam Software Download Demos: VisualMill, VisualTurn, VisualArt, RhinoCAM, RhinoART, FreeMILL, loading a tutorials file that has Machining Operations (Mops) defined and going through this sequence.
    Press Ctrl + C
    Press Ctrl + V
    Are you accusing me of not hitting Ctrl + C and Ctrl + V correctly? Is it the official "support" policy of MecSoft to assume that their customers are completely fabricating the problems they're reporting?
    What do you seriously think is a more likely explanation of me reporting my inability to use standard keyboard shortcuts...
    1. They ACTUALLY DIDN'T WORK.
    Or
    2. I'm completely fabricating the issue.
    I'm surprised that I am the one who has to inform you about this, but...
    There's a phenomenon in the software industry called "bugs". One form of "bug" is where a problem occurs for one person EVEN THOUGH it doesn't occur for another. "Bugs" are common in software development. Just because other people do not experience the same bug DOES NOT MEAN the bug doesn't exist.
    If I do call your tech support phone number and I tell them "hey, Ctrl + C doesn't work" I hope to hell that the "support" agent doesn't say "are you ACTUALLY hitting Ctrl + C or are you lying to me?".
    The insinuation being that I know perfectly well that the functionality is there but I'm choosing to lie about it. And what a perfect thing to choose to lie about too! I mean, as you said yourself: "anyone can verify" whether the problem exists by downloading the demo and trying it for themselves. If I was lying (which I wasn't) you have masterfully foiled my plan to sully your good name.
    I think it takes a real *ss**** to assume their customer is lying about something SO SIMPLE. Talk about hostility.
    Imagine this was a physical piece of electronics, like say, a TV.
    Customer: "Hi my power button doesn't work."
    Support: "You're lying, you're not really hitting the power button. You're banned."
    Yeah, that's SO much better than using "Ctrl + Z". So intuitive too.
    Cool, that's good to hear.
    This is a minor point, but you obviously DID contact me. You put a post on your forum to which I replied. Later you banned me from the forum.
    Lets clear the air here. I have a simple question...
    Is the MecSoft.com Support Forum affiliated with MecSoft?
    If it is an official branch of MecSoft I would say that I DID in fact contact you directly.
    You may note that this thread wasn't created until AFTER the ban on your support forum.
    I'm not saying you're wrong, different people will have different perceptions even given the exact same data. I am a reasonable person and when I look at that thread I see something different.
    I see this...
    Me: "Tool A doesn't work."
    You: "Use Tool B."
    Me: "No, you're not understanding. I want to use Tool A."
    You: "You're banned."
    You want "information"? Try this:
    Hi, I'm trying to use one of your tools to mill a SQUARE HOLE! For some reason your thousand-dollar program is creating diagonal rapids all over the place for seemingly no reason. How can I fix this?
    Let me reiterate the only relevant "information" to enhance your comprehension of the problem at hand.
    I wanna make square hole. Your software is making random diagonal rapids and cuts all over the place. How can I fix this?
    A third time...
    I'm trying to make a square hole. Presumably the program would simply create a square toolpath at one depth, then repeat it over and over again until the bottom of the cut. Instead of this logical behavior your program has made an erratic mess of rapids and diagonal cuts that make little to no sense. I estimate the "erratic mess" is adding about 33% more time to this cut. How can I fix this?
    The crux of the "information" I've offered is "How can I fix this?" The pivotal word in that phrase is "fix". Conflating "fix" and "ignore" is a surefire way to provide poor support.
    If I had come to your forum and asked "dur, how I make hole?" your "support" would have been perfectly appropriate. But that's not what I asked and your support didn't help. I asked why the program was acting the way it was acting. You essentially said "ignore the erratic mess, use something else". "Don't worry about the problem, here's a way to ignore the problem." "Your kid's crying wont be a problem once you fix it with this pillow."
    I don't want to fix the symptom, I want to fix the PROBLEM. There's a distinction. Would you agree that this is an important distinction?
    It's nice you offer phone support to all your customers. As a customer who has been banned from getting support on your support forum I'm very glad that there is another avenue to get support. I'm a pleasant person by nature but I'm going to get pretty pissed very quickly if your phone support starts off the conversation by calling me a liar.
    I thought I recorded a video of this as well, but I cannot find it now. If I do locate it I'll post it on YouTube. If the problem still exists I'll record a new video and post it on YouTube. Like before, if the issue is fixed I will remove the video from YouTube.
    One way or another the problem was there. I believe the only quantitative estimate I gave to the frequency of this problem was 50%. It was actually closer to 80%. There were several occasions where I had to save the file 7 or 8 times in a row before the RhinoCAM data would open in the second instance of Rhino.
    Hi. Can you point to a single instance where I claimed there wasn't some kind of workaround for this issue? Before you start looking I'll save you some time: I never said nor implied that. What I said is I don't like your deliberate design decision. Yes, I AM a power user - I would like a program that does what I want without having to resort to workarounds. Any simpleton can find and be happy with a workaround. I'm sorry that I'm more demanding than your average user... I just got a great idea: use that as your slogan! "MecSoft: We have the least demanding customers!" That way power users like myself (people you like to ban from your forum) will know to steer clear.
    Again, "Tool A doesn't work? Just use Tool B. You're banned." isn't a solution I'm interested in.
    Obviously, you have the ultimate control over what goes into your software. I don't expect you to tailor your software to all my whims. My original post was a list of reasons NOT to buy RhinoCAM, not some kind of list of problems everyone the whole world over will have with RhinoCAM.
    Great on both counts! As angry as I am for being banned from your support forum I am still willing to post where MecSoft has resolved the issues I've had. I think it's really great that you're willing to take suggestions from me, even though I'm being irate.
    I know you're not a terrible company. I've already said I don't "hate" you. I've even bought another piece of your software (in a round-about way) since creating this thread. Who knows... when I install RhinoCAM again and put in the 4th axis plugin maybe all my problems (maliciously fabricated or otherwise) will have gone away and I'll be a RhinoCAM cheerleader.
    As I recall the other setting was not available to me (grayed out). I suspect it was disabled because I only own(ed) the Standard version of RhinoCAM. No, I'm not happy that the superior rendering option is reserved for your "better" customers. Turning up the detail just exaserbated the "slowness" issue I was having (before you jump to any conclusions: I swear, I'm not lying about it).
    See attached images.
    Sure, I'm ignorant of what else is out there. Most companies don't even offer a demo. I mentioned in a previous post several other CAM packages that I have crossed off my list for various reasons. I've even posted since my original post that I agree that RhinoCAM may be the "best" in its price range. However, being the best of a group of crappy programs doesn't make RhinoCAM "great". It only means it's less crappy.
    Personally, I prefer software that saves its settings in an ini file. They're easier to backup and restore and it also avoids some inherent problems with the registry. The fact that my reverting settings issue can be blamed on Rhino crashing (something it almost never did ON MY COMPUTER before RhinoCAM was installed) doesn't exactly clear RhinoCAM of culpability. There should be safeguards against software crashes.
    No, I was not able to turn off the automatic check. As I recall, the option is only available under certain conditions. I think the option was only available the first time it checked for an update or only if an update was actually available. Again, I'll record it on video next time.
    I thought advanced toolpath editing was available in the basic version of RhinoCAM 1.0. Although I looked, I couldn't find any evidence to support this. I may have been mistaken.
    Attached Thumbnails Attached Thumbnails Screenshot - 10_4_2010 , 6_36_14.png   Screenshot - 10_4_2010 , 6_43_53.png
  13. #33
    May 2012
    lol
    I am brand new to this forum and the CNC world but I am a engineer. This thread has kept me laughing so hard my gut hurts!
    Someone for SURE has way too much time on their hands to type all that trash.
    My opinion of Rhinocam - tech support called me before I even installed the software!
    LOL!
  14. #34
    Nov 2004
    436
    Weiser,
    Agreed.
  15. #35
    Mar 2012
    378
    I have RhinoCam 1.0 and have not been completely happy with it. Possibly a lot of the problems I have with it were fixed in the later releases, but I am fairly reluctant to spend more money on a program that I am not happy with.
    The mm to inch switch is a big pain. I do my part models in AutoCad then import to Rhino for CAM since I am much better at AutoCad. I get it to work by opening a file that was done in inches in Rhino, deleting the operations, deleting the old part, then inserting the new AutoCad part and renaming and saving the file. It is a big PITA, but it works.
    I have not tried calling tech support about it yet, but I had a major problem with a file to drill a bunch of holes. Normally I do a lot of 2.5d profiling work on the router, but needed holes for something. I set it up to peck drill, but it never would peck, just drilled full depth. It also would drill then it would retract the bit while moving to the next hole instead of retracting the bit then starting the move. I had to manually modify the G code to do the retraction first. I wound up on this part manually moving the Z axis and running 8 passes at increasing depth since I never could get the program to peck. Took an hour to drill the holes instead of the 10 minutes it should have. Now something this simple I am confident I could have fixed with tech support, but I had to do this on a Saturday. I can't imagine that bugs like this are not something that was fixed, but I sure could not find the solution.
    One thing I can't stand with RhinoCam is that it needs a dongle and if the dongle is lost, you just lost all your money. I keep my dongle in my safe when I am not using it, but keep it on top of my laptop when I am working a lot with it. Several times I have had to search for it when my wife cleaned up even after warning here that the purple thing is a $1,000 dongle, not a memory stick.
    I was just looking yesterday at MadCam. It is a lot less expensive and I will give it a serious evaluation when I need to upgrade to 4 axis soon.
  16. #36
    Sep 2004
    264
    Well, RhinoCAM 1.0 is now 2 versions old, but:
    RhinoCAM 1.0 would either work in inches or MM, but not both, if you changed unit systems it would exit. But that doesn't explain the necerssity of the procedure outlined above. RhinoCAM 2012 will not exit if the units are changed, but the machining data is removed. Generally you do not change unit systems in the same file, though.
    The solution is in having the correct postprocessor for your machine, and thoroughtly testing it before you run important parts. This is not a RhinoCAM problem, this is a post config problem. "Out of the box" postprocessors almost always need tweaking.
    Dongles are reality in many CAM systems (virtually all higher end ones) and even some other types of programs (one of my rendering software packages requires one). I'm not fond of them either, but that's just the way it is.
    MadCAM is an excellent program. It's toolpathing capabilities are excellent, better than RhinoCAM's in many ways, but you will find it does work a bit differently than a "classic" CAM program.
    --ch
  17. #37
    May 2007
    44
    The only problem RhinoCAM 3 is not in SPANISH, the language most spoken in the WORLD ..!
  18. #38
    Sep 2005
    1660
    Actually, Mandarin is the most spoken language, followed by English, Hindustani and then Spanish... but who's counting.. [At least according to Top 10 Most Spoken Languages In The*World - Listverse , Wiki shows Spanish as #2 (0.02% ahead of English)]
    JerryFlyGuy
    The more I know... the more I realize I don't
  19. #39
    Sep 2009
    3
    Hi i was watching Hirudins post and would like to say a few things..Work with rhino for 6 years (rhinocam2).Started with rhino 1 and just changed to rhino2 cause it had chamfer function..if t wasnt for that i think i would still use the first one.Since the begining lots of problems with finishing details...awfull paths that give bad look at our moulds for glass industry..Stopped moulds for glass and started working on punches for auto industry..Cause we only do rough work no problem.a few moths ago started working for another industry and problems begin again..Posted it in mecsoft forums and the best answer ws to delete it...see the pictures of toolpath generated..anyone who uunderstands minimum of toolpaths in steel can see that all of them mean killing tools...In one day 600 dollars in 3 indexable endmill plus 15 inserts...(5 each endmill).
  20. #40
    May 2005
    387
    I went with madCAM ( madCAM CAM plug-in for Rhino3D ) for a lot of reasons.
    It was developed for the mould industry by mould makers. Works just like Rhino Cam as a plug-in to Rhino. At least you have options regardless of which you prefer.
Page 2 of 3 123
  1. 7 Reasons You Should Consider a 5-axis CNC Machine
    By cncadmin in forum News Announcements
    Last Post: 10-11-2013, 12:40 AM
  2. 7 Reasons You Should Consider a 5-axis CNC Machine
    Last Post: 10-10-2013, 03:25 AM
  3. 5 Reasons To Treat Your CNC To ArtCAM Express
    By Chrisartcam in forum News Announcements
    Last Post: 04-04-2012, 02:38 PM
  4. there are some real good reasons
    By cabnet636 in forum Camaster
    Last Post: 07-08-2011, 12:31 PM
  5. looking for any reasons not to buy an rf45
    By lost_cause in forum Benchtop Machines
    Last Post: 06-15-2010, 03:30 PM
