587,401 active members*
3,309 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Recommend Solution For Single Axis
Results 1 to 13 of 13
    Jul 2008
    68
    I have this bridge saw with no controller. I have spare servo drives, motors and some stepper motors and drives.
    Also I have AC Drives with gearbox motor. The AC Drive is Teco MA7200 with lot of features.
    which I can use to drive the cutter head if possible. I think the gearbox was previous used with the saw.
    I don't plan to use a computer to control this saw because is just one axis only forward and reverse direct.
    What I like to have is the following:
    1. Control the speed of the axis Forware and Reverse during cutting.
    2. Jog to position with different speed.
    3. Automatic home position when it hit the right limit switch.
    What is the best solution for this requirement.
    Jan 2006
    121
    I would suggest some small micro-controller for the project, but some fancy logic on a PLD could handle the requirements.
    Jon
    Aug 2009
    392
    I'd make some sort of standalone controller using a microcontroller. All you'd need is dir and step signals really, and then some inputs such as a joystick.
    As for the limits, it'd be as easy as wiring it to an input and writing the proper code.
    Jul 2008
    390
    I Second That!
    Quote Originally Posted by Jesse B View Post
    I second this. My thoughts exactly. I'd use an AVR and a driver chip like those on standard driver boards with dir & step configuration.
    Do you have any experience programming microcontrollers?
    Oct 2005
    1237
    Heck you're only going forwards and back and need to control the speed and a jog? If your servo drives use analog signals for speed control, just a simple rheostat will work. Anything more is extra work. The servo drive ends up working like a simple DC drive
    Dec 2003
    24223
    Many drives also have fwd & rev limit inputs, each only allow movement in the opposite direction.
    Al.
    Albert E.
    Jan 2009
    237
    Many commercial servo drives have such features built in . Check out the Emerson FX series or the contemporary equal for ideas. Perhaps a little spendy, but good solid drives combined with Programmable logic control capabilities.
    Jul 2008
    68
    Quote Originally Posted by amishx64 View Post
    No, I don't have any experience with programming microcontroller.
    Dec 2003
    24223
    If you list the drives and motors that you have and looking to using, it may be possible to offer more assistance, you don't necessarily need intelligent drives for that application.
    Al.
    Albert E.
    Aug 2009
    392
    It's not required, but I think it'd be nice to be able to run them at a known speed, and adjust it to fairly precise speeds on command. It's not necessary, but for the amount of work it'd take it might be worthwhile.
    Dec 2003
    24223
    Thats an idea, If they are older DC servo's with Tach's, a digital or even moving coil volt meter could monitor the tach voltage for a quick simple method.
    Al.
    Albert E.
    Jul 2008
    68
    Currently I have two AC Drives that I use for this project the Drives are from TECO model MA7200 and 7300CV. The 7300CV has PLC functions built. This is description for the drive. I think it should be able to do what I need but I am able to hookup the motor manual push the button for forward and reverse.
    What I like to do is able to automatic home when it the reach the end limit switch and before home it actuate a switch and when it sense successfull activated and activate the reverse to home position.
    7300CV Series Compact Vector AC Drives
    Product Features
    Auto-tuning Sensorless Vector Control with V/HZ mode
    Pulse Width Modulation (PWM) utilizing IGBT Technology
    Built-in PID Control
    2 Analog Inputs: 1 master speed reference accepts 0-10VDC, 4-20mA, and 0-20mA signals and 1 multi-function (0-10VDC)
    Digital Inputs: 5 PNP/NPN selectable
    1 Analog Output (0-10VDC)
    2 Multi-function Digital Relay Outputs
    Built-in dynamic braking transistor
    Electronic overload protection and stall prevention
    Ground fault and short circuit protection
    Built-in PLC functions at no extra cost
    Ladder logic programming, up to 40 rungs of code
    Up to 7 Digital Inputs, 2 Relay Outputs, 2 Analog Inputs
    8 Comparators (4 analog, 4 encoder)
    8 Timers, 4 Counters, 15 Internal Relays
    Dec 2003
    24223
    If it has a built in ladder, you should be able to accomplish what you want within 40 rungs of code.
    I am not familiar with the ladder in those, but presumably it is fairly easy to program? no extra hardware or software required?
    Al.
    Albert E.
  1. Single axis motion without PC?
    By marzetti in forum CNC Machine Related Electronics
    Last Post: 05-27-2013, 09:29 PM
  2. Simple Z axis solution for BP J Head retro
    By DennisCNC in forum Bridgeport / Hardinge Mills
    Last Post: 07-24-2006, 04:41 AM
  3. 4th axis solution to solve gantry skewing, geckos and servo, and axxus questions
    By CuttersCov in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-20-2006, 11:10 PM
  4. single axis controller
    By robm7 in forum Stepper Motors / Drives
    Last Post: 10-22-2005, 07:30 PM
