587,482 active members*
3,398 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Low Current interface, High Current Motor?
Results 1 to 16 of 16
    Mar 2009
    13
    I'm thinking of buying a small (compact) stepper interface, rated less than 2 amps per phase, but I want to run it on a 2.5 amp per phase stepper motor. Can anyone tell me if I can get away with just putting an FET on each phase?
    I am CNC'ing a large'ish' Mill, so I need fairly powerful motors to run it. I know it is easier and simpler to buy a >2.5a rated controller, but this controller has button controlls so I don't have to boot the very slow, very old laptop to move the leadscrews (I also have mobility problems) The mill is a far eastern model purchased in the UK from WARCO, model ZX-15 and I am on a non existant budget.
    I'm no expert when it comes to electronics so be gentle with me. Any information would be great, thanks
    Ian
    Aug 2008
    74
    It isn't necessarily a good idea to run steppers at their current limit; they'll get pretty hot. Running them slightly under that limit would be fine.
    At a guess, if it were an easy thing to uprate a motor driver, it would be done more often and geckodrives wouldn't do such good business ;-)
    Mar 2009
    13
    Curent
    Hi serriadh,
    Thanks for the comments. I think I may not have made myself clear. I don't want to run the low current driver at max, I wondered if it was possible to add a power FET on each phase to take the load, so the driver wouldn't strain and burn out.
    Thanks anyway...... Clackvalve
    35538
    A drive won't try to deliver more than it's rating. If it's a 2 amp drive, it'll deliver up to 2 amps, all day long. You won't damage it by using higher current motors. The drive dictates the current, not the motor.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2009
    13
    Hi, Thanks for the info ger21, I didn't know that. I guess there must be a current limmiting circuit of some sort built into the controller?
    I'm trying to find out if I can add a fet to each phase, so I can use the motors at there full potential....
    Clackvalve.
    Jan 2006
    121
    Yes
    Quote: "I'm trying to find out if I can add a fet to each phase, so I can use the motors at there full potential....
    Clackvalve. "
    I'm not sure of all the details, but it should be possible to add a secondary amplifier to the output of your drive. This would mean another power supply with a larger transformer and smoothing caps (unless the supply you have is sufficient for the load). It would also mean having the correctly designed switching circuitry for the FETS in the 2nd stage, considering the 1st stage output characteristics.
    There maybe some sacrifice in performance, but maybe not if properly designed.
    Jon
    Mar 2009
    13
    Hi, JonLed,
    The switching circuitry is the bit that is beyond me, I know that when these steppers are moving there is a portion of back emf to consider but I think I could just bung a fast diode in front of the fet to stop that doing any damage.
    Power supply is not a problem, I have a variable voltage 30A PSU to hand so no probs there. The driver I am considering is in the UK If your interwested its here>>>> http://www.virtualvillage.co.uk/step...06408-001.html
    cheap but as I said in a previous message the buttons are useful.
    Clackvalve.
    Jan 2006
    121
    That uses a L298 driver, if you're good you could parallel another to it, see data sheet. There are tons of DIY drives on this site you could go with instead you messing around with mods. How largish is this machine anyway?
    Jon
    Mar 2009
    13
    Jon,
    I have seen a few L298 circuits dotted around but they all seem very simple circuits I am all for KISS philosophy but I would like to be able to add a simple remote so I can use the mill without having to boot up my rediculosly slow very old laptop every time I want to use the mill. Hand cranking is very difficult, I have early onslaught Arthritis.
    That is why I am so desperate to use the controllers I described. Not only are they cheap (£8.99) but they have forward, reverse, fast & slow buttons I can use. I have to admit I haven't had a look in the files lately so I'll have a butchers to see if there is any inspiration.
    Thanks Jon....... Ian
    Jan 2006
    121
    A simple micro-controller could be interfaced to just about any stepper drive to give you those functions you want. You didn't mention how largish this machine is. Are you sure 2.5 amps is going to give you enough torque to move it?
    Jon
    Jan 2006
    121
    Ok, I found the mill here http://www.warco.co.uk/ZX-15-Milling...B040AEC96.aspx
    Do you have any experience making PCB's?
    Jon
    Mar 2009
    13
    ZX-15
    Yes, I have made many pcb's. As a radio ham I have built many commercial kits. I have made a few "spider web" PCB's, and chemically etched them. I dont have the UV stuff now though I have still got the heated etching tank. Of course mostly RF/audio.
    Yep, that is my mill, I should say it is of oriental origin and has no ball race type bearings "YET" and there needs to be some polising of gibs and ways etc all making it more difficult to crank so I thought I would combine both projects into one. That way I won't have to take it apart twice.
    The micro controller sounds a little involved, I was hoping to keep this strait forward, hoping that the down time is kept to a minimum. I have no commercial interests but I do have an estimated 5 year project I am about half way through. There will of course be a time that I will not be able to use the machinery so time is limmited for me. Again that is why I was hoping that the controllers I found would do the job.
    Ian
    Jan 2006
    121
    You could do the same thing with a 555 timer and some logic, but the uC would simplify things. I guess what I would do if I was in a hurry, would be to buy one of those drives and see if it will do what you want. If it does, then it would be easy to swap out the drives for higher power ones later.
    I'll see how simple I can make a little manual controller board, give me a few days.
    Jon
    Mar 2009
    13
    Hi Jon
    I have commited to 3 board kit (3 sepperate boards) from Routout today. You can see them here: http://www.routoutcnc.com/lpkits.html I chose these because I have used them in the past on a mini lathe I no longer have but I have knowledge of the boards and know they will deliver 2.5A all day.
    Like you I am thinking of a "hand" control unit. I think all I will need is switches for direction and enable/disable and a variable resistor connected to a pulse width modulator, I have found a circuit that uses 2 555 timers to generate the PWM here: http://www.eleinmec.com/article.asp?28
    It apeals because it looks simple to build. I would appreceate your thoughts on if I need a pulsed width modulation or just a bog standard osc. I think just an osc. will do the job but not 100% sure. The motors I intend to use are 8 wire hybrids and to make them compatable with the boards the centre taps are linked. So I guess the 555 o/p will need to go through a flipflop to alternate from one coil to the other.
    Thank you for your offer to give up your time to help, I hope I have saved you that job and look forward to hearing from you soon....
    Ian
    Jan 2006
    121
    You're right about not needing PWM to operate those drives. Just a switch for direction, maybe one for enable, and a square wave to make it move. You'll probably want some means of varying the frequency to control the speed of the motor. An easy single 555 project.
    Then you'll have to decide whether you want one for each drive or a switch to select which drive you'll be indexing.
    Jon
    Mar 2009
    13
    Well, that makes it easier Jon, thanks for that info, I wasn't sure if it wanted a PWM but couldn't see why, I thought I may be missing something.
    I wan't sure weather to make 2 (XY) hand controllers or one with a 2 way 4 pole switch. I have dedcided it would be a neater job with one board and a switch.
    Thanks for your help Jon it is very much appreceated.
    Ian
  1. High Current 5V power supplies.
    By vger in forum CNC Machine Related Electronics
    Last Post: 02-16-2010, 03:29 PM
  2. High current on the PIC outputs?
    By 3dfernando in forum Stepper Motors / Drives
    Last Post: 05-29-2009, 05:35 PM
  3. need high current regulator circuit
    By tekno in forum CNC Machine Related Electronics
    Last Post: 05-23-2006, 02:00 AM
  4. High current motor controller
    By TinkerDJ in forum RC Robotics and Autonomous Robots
    Last Post: 11-27-2005, 09:56 PM
  5. Cheap 24V High Current Supply
    By ehiebert in forum DIY CNC Router Table Machines
    Last Post: 04-11-2004, 06:09 AM
