587,221 active members*
3,034 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2007
    980
    LED Electronics guys out there?
    Hi fellas, I've been putting together a new spindle light for my Taig Mill and I'd like it to be much brighter than before. In the enclosure, I have enough room to house 23 (yes, 23 lol!) LED's but I'm not positive about the best way to go about wiring them.
    Some info:
    23 white LED's
    - forw. voltage 3.4
    - forw. current 25 mA
    Source will be a 9.5 volt Apple printer Power supply with 1.5 amps available
    I've used the online calculators and I come up with 23pcs. 270 ohm 1/2 w resistors, but that's an aweful lot more parts to stuff in there. I bought one of those $5 puck lights that has 24 LEDs in it and they don't have hardly anything like that inside. They use those tiny little surface mount resistors, but there's like only 2 of them in there? Is there a cleaner way to do this with a lot less parts? I honestly don't mind soldering all that, but it just seems to be too much for what I'm trying to do.
    Obviously I'm not an electronics guy, I just know enough to be dangerous -
    Thanks for the help and your time-
    Dave
    Dave->..
    Dec 2003
    24223
    I think I would look at higher intensity LED's, ones already in a known base e.g. MES or similar, or better still, I would look at the types you can buy now to replace automotive incandescent, these are clusters of high intensity lamps all in one, you just need a 12v supply.
    Al.
    Albert E.
    Nov 2007
    980
    Thanks Al, but I already have these setup and ready to go in the housing.
    As for the automotive, I'd have to tear that part and who knows what I'd have left after doing so...
    Thanks,
    Dave
    Dave->..
    Feb 2010
    Have you tried 3 in series. You would not need a resistor then if they really drop 3.4V each. Is the power supply unregulated Too bad 23 is not divisible by 3.
    Dec 2004
    1137
    http://led.linear1.org/led.wiz
    I used 12V, 3.2V forward voltage, 20mA, and 23 LEDs.
    -Jay
    Jan 2008
    124
    Thanks for the link Jay, that will come in handy at times. Fretsman, you can use resistor arrays that come in 16 or 18 pin DIP packages ( I.C. style ), that way your setup can be more compact. Just remember to not exceed to total power dissapation of the device.
    Feb 2010
    Nice calculator link. Got me to search for LED characteristic. Found another link to a calculator discussing various series conections: http://www.ledtuning.nl/index_site.p...e=ledtechnical
    Nov 2007
    980
    Thanks for the info and the help all. Definitely some food for thought here and the link posted by Curley is a fantastic link, thank you-
    As for the power supply, it is not marked if it's unregulated or not as it's just one of those larger wall wart types.
    Dave
    Dave->..
    Dec 2003
    24223
    Quote Originally Posted by fretsman View Post
    Dave
    Most are not, an easy way to tell is check the off load voltage, if it is as stated on the label, then it is regulated, if quite a bit higher, then unregulated.
    Al.
    Albert E.
    Nov 2007
    980
    Thanks Al, just did a quick check and it's 13.03V
    How much can it fluctuate and is it a bad idea to use a wall wart type PS?
    Dave
    Dave->..
    Dec 2003
    24223
    They normally go down to the rated voltage when run at the rated current, so anything in between is a guess.
    If you want a guaranteed voltage, either make or buy a regulated one or stick a regulator on the output, the down side is the regulator will consume some of the rated current.
    If you are drawing that low of a current total, why not use one of the PC 12vdc supply connectors?
    Al.
    Albert E.
    Nov 2007
    980
    I actually played with the idea of doing that but I just hate to rob any power coming from the machine PC.
    One of those "anal" things I guess. It's not like I'm using anything else, like any of the drives, so I'd probably be fine. If it's going to quit on me, it's not like it'll be the spindle lamp's fault
    Thanks again-
    Dave
    Dave->..
    Dec 2003
    24223
    Wire a small in-line fuse holder in it!.
    Al.
    Albert E.
    Aug 2004
    2849
    Look, you're not planning a trip to the moon.....I would just use the 20 ma x 23 Leds to be the total current draw. For the voltage I would use 13 volts - 3.4 volts...say 10 volts.
    Using R= V/I then 10/.5 so you end up with a 20 Ohm resistor.
    To size the resistor the use Power = I squared R or (.5 x .5) X 20 = 5 watt resistor so that is a pretty physically large resistor...so see the correction below
    That should be correct...if not someone who is not inebriated will catch it.
    Paul
    Jay C you should have corrected it to five 100 ohm 1 watt resistors.
    Dec 2004
    1137
    Quote Originally Posted by ViperTX View Post
    Wrong.
    Nov 2007
    980
    Got my breadboard and did a little experimenting today,
    Went with this array setup for the experiment:
    Dave->..
    Nov 2007
    980
    Turned out well and now you can see why I needed such a small fitting setup as the channel everything is housed in is very very small. The laser incorporated more compactly and closer to the spindle centerline will be a nice improvement as well.
    Now to get it mounted with a switch and we're good to go-
    Thanks for the helpful info once again-
    Some pics for you all.
    Thanks,
    Dave
    Dave->..
    Nov 2009
    4415
    I bought one off ebay years ago that looked very similar to yours but it only had leds in 2 corners. Still worked very well.
    Nov 2007
    980
    Quote Originally Posted by Fastest1 View Post
    Yes, I've seen that one and it's like night and day as compared to this one. Literally, night and day
    Thanks,
    Dave
    Dave->..
    Jan 2010
    110
    Very Nice
Page 1 of 2 12
  1. How do you guys do this?
    By slideleft in forum Mastercam
    Last Post: 07-10-2009, 02:14 AM
  2. Hi Guys
    By Jack000 in forum Community Club House
    Last Post: 10-27-2008, 12:21 AM
  3. Hello guys
    By Cuttermaster in forum Benchtop Machines
    Last Post: 10-22-2008, 04:15 PM
  4. Hi guys
    By jordancnc in forum Sharp CNC
    Last Post: 09-30-2008, 03:13 AM
  5. You guys aren't doing your job!
    By CerveloRod in forum Benchtop Machines
    Last Post: 03-20-2005, 05:30 AM
