587,829 active members*
2,893 visitors online*
IndustryArena Forum > MetalWorking > Mass finishing equipment/media/strategies > Custom built .063" aluminum sheet polisher.
Results 1 to 9 of 9
    Feb 2010
    3447
    So i have seen a tumbler and vibrator polisher with all different kinds of media work excellent on polishing aluminum, brass, copper, you name it. My question to you is if i load in a 20"x20" sheet of .063" aluminum into a custom built machine, made by myself can i polish a sheet to the same luster as small parts?
    What media would you recommend for 6061-T6 aluminum? I've seen friends polish it to a mirror finish by hand, but can i polish a sheet to a high luster/mirror by using the machine.
    Thanks.
    Feb 2010
    3447
    ** bump **
    I see the normal vibrating units that are made to polish like gun ammo (brass) but cant i take the small bucket off and attach a larger custom holder that holds sheet and load in the polishing media? sounds like it should work in theory.
    Mar 2007
    156
    It probably will not work in practice. I have tried putting flat objects (say 4"x4" flat pieces of 16 gauge steel) in my vibratory deburring machine. It didn't work well. The parts floated to the top and only got slightly scratched up from the media (and only on the underside) - instead of circulating throughout the media and getting worked thoroughly. So, a very large flat piece, even with a custom built bed, will probably also float to the top and fail to get properly polished.
    Feb 2010
    3447
    What if I were to fix the piece in a custom jig centered in the media so it won't float?
    Feb 2007
    4553
    [nomedia="http://www.youtube.com/watch?v=T6xkE-Xo4SA&feature=related"]YouTube- Aluminum Fuel Tank restoration.mov[/nomedia]
    www.gordsaluminumpolish.com
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2010
    3447
    When i worked @ Boeing believe it or not, thats how they would polish the plane to a mirror shine on some of the leading edge aluminum sections. They also used that technique to take micro chips out so they overtime did not spread and open up the aluminum sheet like a zipper form a stress fracture.
    I wanted too put multiple sheets in the vibrator and let it sit overnight, take the human factor out of the equation haha.
    Feb 2007
    4553
    Post
    Lots of water will be consumed keeping the media clean.
    I believe most manufactures that are using sheet goods to construct there product are using a buffer.
    Jeff...
    Feb 2010
    3447
    Quote Originally Posted by jalessi View Post
    Jeff...
    Oh dang! I guess i will have to look into a monster buffer haha.
    Mar 2007
    156
    Quote Originally Posted by diyengineer View Post
    Yes I suppose that could work.
  1. Custom Built and Machined Rose Engine
    By wwendorf in forum Wood Lathes / Mills
    Last Post: 03-30-2010, 11:44 PM
  2. Looking for thin aluminum, 0.020" thick, sheet
    By laka in forum MetalWork Discussion
    Last Post: 06-26-2009, 06:32 PM
  3. rfq-----custom black plexiglass sheet
    By tooldzinr in forum Employment Opportunity
    Last Post: 05-28-2009, 04:16 PM
  4. Custom built CNC Lathe - Long term project
    By pstockley in forum Vertical Mill, Lathe Project Log
    Last Post: 04-15-2008, 12:50 PM
  5. Cutting 1/4" aluminum sheet
    By energyforce in forum MetalWork Discussion
    Last Post: 12-01-2005, 08:12 AM
