587,481 active members*
3,110 visitors online*
Results 1 to 6 of 6
    Feb 2005
    27
    threading help!!! asap
    I need help with threading issues... I want to make .485-18 un-2a thread with a major tolerance of .485 to .478 and a minor tolerance of .448 to .443.
    I have a fanuc O-T control. Could someone out there help with the g-code I should use, I tried g32, g92, and g76 whiuch one is best. and could a sample program be provided?
    Any help would be greatly appreciated (chair) (chair)
    Feb 2005
    303
    G76 is the easiest to use, and requires the least amount of code.
    G76 P010060 Q5
    G76 X.4455 Z-1.0 P360 Q5 L.055556
    Feb 2005
    27
    thanks ghyman I entered in the info given it did indeed make a thread but the but the pitch was so fine it wiped out the major diameter!! I can get the pitch correct with a g32 but the threads come out full of burrs,and I 'd really like to use a canned cycle instead of punching a million numbers in manually. I got 1000 of parts to make and they get plated so they must be flawless. I bought this machine used and haven't had to thread anything until now. I have never run into this problem before I've been on the floor programing and machining for 15 years. I am using a g97,g99,g20 so that is all there. I am begenning to think bad encoder??????
    Jan 2005
    304
    T0101
    S1250m3
    G0x.5815z.1
    G4u.5
    G92x.4595z-.5f.05555
    X.4459
    X.4353
    X.4263
    X.4183
    X.4133
    X.4133
    G0x.5815
    Feb 2005
    27
    thanks guys I found the problem today a bad wire to my encoder as soon as I fixed the frayed wire it worked fine. Back making parts. I guess I learned a lesson getting a used machine at a bargin basement price will cause alot of head aches until you get all the bugs worked out. I can't afford a repairman at $150.00 an hour so I am on the learning curve. Starting you own shop is such a joy just waiting for the rewards..................
    Feb 2005
    303
    Wow! scared me there for a minute! I hated thinking that I posted bad code!
    Glad you're back up and running!
    As for "waiting for the rewards..."
    There are rewards?!?!?
    gmh
  1. Okuma LC-20 Threading problem
    By Gunner in forum DNC Problems and Solutions
    Last Post: 12-14-2011, 05:11 AM
  2. Deskcnc version that supports threading
    By Dan Mauch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-05-2005, 12:51 AM
  3. Threading tool recomendation
    By Toddjones in forum DNC Problems and Solutions
    Last Post: 02-18-2005, 07:55 AM
  4. Four start threading using Mach2 ?
    By Bloy2004 in forum Mach Software (ArtSoft software)
    Last Post: 02-12-2004, 05:57 AM
  5. Taig lathe Threading and CNC questions
    By anoel in forum Mini Lathe
    Last Post: 01-12-2004, 10:43 PM
