Originally Posted by
revwarguy
I use Cambam, Aspire, and Mach 3. Wasted time on Lazycam, just too unpredictable - I couldn't really depend on it to produce what I needed to do, so if I have to learn something well, I'm gonna go with something that is more solid. Not knocking it, as the price was right, but I just don't seem to have the time anymore to invest in learning erratic stuff that will probably force me to use something else anyway. Don't think there is a solid open source CAM freebie yet.
But hey, if you've already got Cambam, you have a lot. If you take a bit of time to get used to Cambam, it is very fast for making simple parts. I just used it to make the disks of mdf for the PVC drum sander. I don't think it took me longer than 2 minutes, including a pocket for the rods to fit in, complete with holding tabs, etc. and I am not what you call a power CAM guy. I was a bit frustrated with it at first, but then the light bulb flashed and I was off with it. It suffers from the lack of a good tech writer to do a little documentation. The video tutorials are a help, but they're just not nearly enough. Cambam's pretty new, and there has been good stuff added in each release.
Started off with V Carve, and it is very, very good. Easy, intuitive, and I don't use those words lightly. I ponied up and went to a Vectric user group meeting in Dallas last November, and was sold on Aspire (an upgrade to Vcarve that uses exactly the same User interface that does 3d modeling and 2 rail sweeps) but its pricey. With these I can take an image and convert it to a vector drawing and then to a toolpath pretty quickly, depending on the image.
If you need any help with Cambam, just let me know. Stay warm.
